ALEX
Fuel Pump Relay - Availability ? (New 2026)
ALEX
AKA Tachometric relay, This relay connects the pump to the 12V feed with the engine running. It uses a Tach signal to engage the relay.
The only brand (or latest brand to manufacture these seem to be Meat & Doria.
Though I'm stuck between knowing which part number between two options.
Google is saying I need 422040. but I can only find 422011, which looks the same part?
Can anyone advise?
ALEX
19 minutes ago, DamirGTI said:
Not much left , so best to stock up :
https://mai.es/en/product/fuel-pump-relay-opel-2/
And yes , Opel/Vauxhall item works .
is the 422011 the Opal / Vauxhall one? Will it work?
There seem to be a quite a good availability of those on ebay.
DamirGTI
It seems like so yes , it is listed as Opel item ..
Opel/Vauxhall used the same Bosch Jetronic management back in the days and quite a few other makes/models from that era too .
I've OE Opel Kadett 2.0 fuel pump relay on mine for well over 15years now , only difference is that it primes for a sec. with the key ON .
Different PSA numbers might be just brand wise , one for Bosch and another for Cartier or Valeo .
SRDT
From just a few days ago:
