DamirGTI
Oil or gas shock absorbers ?
DamirGTI
Posted (edited)
Im in the middle of restoring 406 for my daily drive , and thinking about which shock absorbers would be best ideally to match the OE Peugeot ones .
As we know , Peugeot used to be pretty picky in terms of suspension and making they're own shock absorbers up to year 2004 (or 2014 ?!) from what i read , and afterwards all PSA cars now are fitted with KYB shock absorbers .
If im not mistaken , factory fitted shocks on 406 are twin tube oil/hydraulic type , but commonly known replacement closest to OE spec Bilistien B4 are gas filled instead classic oil/hydraulic .
Not sure which ones to go for , oil or gas and which brand to match the OE ride as Peugeot ones aren't available anymore .
Removed and checked the old ones and they're all dry , suprizingly even the bump stops and dust boots are still good with only the top mounts havnig some rubber cracking/dry root ... which made me thinking maybe the shock absorbers are still good too ?! (after 290.000 Kms)
Edited by DamirGTI
Thijs_Rallye
Afaik Peugeot used to buy Sachs or Boge dampers in that era.
DamirGTI
They seem to be Peugeot units .
Theres very long 17 digit number code and Peugeot embossed on the shocks .
Tried to compress the shaft , it goes down with medium pressure but does not go back up on its own like gas filled shock , and while pulling the shaft back up theres resistance which seem like classic hydraulic shock .. or crapped out gas not sure .
From what i read , a lot of people complain that the ride was much worse/hasrh after they fitted new shocks on a 406 , likely gas filled instead straight oil shocks .
I remember an friend of mine fitted KYB excel G on his 406 2.2 petrol and he too was a bit disappointed , the comfy OE ride was gone .
Sachs now offers two variants , "standard" with white sticker and "super touring" with blue sticker . Few years ago there was also version with red sticker i forgot the name for those but they where the stiffest sporty type .
Sachs/ZF site sadly does not say much about specs in detail .
For comparison , i had both Sachs super touring and Bilistien B4 on my 205 and must say it drove better/nicer on Sachs .
Edited by DamirGTI
