Chrisstdt
1.6 8v running badly
Chrisstdt
Bridged the relay, made no difference until I clamped the return hose to tank with grips ,i could get to 2.5 bar on gauge but not consistently
Chrisstdt
Pumped system up with tyre inflator and holds at 3 bar ?
Will go way over when I restrict return hose
Rubber supply hose collapsing internally?
System held 3 bar for several minutes,does this rule out leaky Injectors?
Chrisstdt
Pump delivers around 3 litres per minute with relay bridged
I assume that's ample ?
yes, standard pump is 180Lph so 3 a minute is bang on.
where exactly did you pressurise the system and held 3 bar?
Chrisstdt
Fuel line running to fuel rail
In other news I cleaned the earth behind passenger rear light and sprayed multi plug for tachometric relay with wd40 and she now holds 2.5-3.0 bar with vacuum removed
Perhaps bad earth held pump back under load ??
Going to go for a proper drive later but I'm hoping she's sorted
Glad I didn't drop £354 to repair a working AFM !!!
Chrisstdt
Had her a good 40 + mile run and I'm pleased to say she's been transformed!
All good now problem seems to have been a bad connection either on the fuel pump earth or tacho relay plug
