Gohn
Right Side Sagging
Gohn
Posted (edited)
my TD has started slumping on the Right (drivers) side
its used daily but Im not at all heavy and did not expect any sagging
Original springs / torsion bars / shocks all round
from the ground up thru hub centre to the bottom of the wheel arch:
FRONT
Right - 650mm
Left - 662
REAR
Right - 635mm
Left - 645
Right side is roughly 12mm lower in the front and 10mm lower in the rear
its been suggested on here in the past that the rear follows the front
so planning to swapover the front coil springs first, see how that looks
any suggestions welcome
Edited by Gohn
jord294
Quite common. If a rhd car mainly has driver only and no passenger, then in time it will sag
Ozymandis
Its common to sag on the drivers side.
Dont swap the torsion bars side to side, they are known to snap if You do.
Re-setting the dummy shock a bit  longer on the drivers side and moving the bar round on the splines is what I do to compensate for sag at the back.
