15dbs
Sump oil leak
15dbs
Hi all another  question. I've got a slight oil leak from my sump is it best to use a gasket  or  a rtv sealant.
Leslie green
Depends on the engine , a 1.9 Gti needs both as it  has a sump spacer , the gasket is between the tin sump and alloy spacer.
15dbs
It's a 1.6 mate
Leslie green
I think just rtv will be fine for a 1.6
SRDT
Some oil pan screws are not the same length, if you mix and match on reassembly you can have a recurring leak.
Gasket plus wellseal, the key is going round the bolts with a torque wrench over a couple of days as the gasket progressively settles. Do it just once and it will leak is my experience.
series111
Wynns gasket maker used this for sump replacements for years just use this no gasket required.
PhilNW
Clean faces then sealant and use a torque wrench (dont guess) the torque
