rny
88 mm Crank in XU10J4rs
rny
Hi,
I need to rebuild my XU10J4rs engine due low oil pressure. I wonder how much I will get if I put a
XUD11 88mm crank with S16 rods and pistons?
Or is it better to go standard?
Regards, Robert
That is definitely the easiest (cheapest) way to do it, otherwise you'll need new rods as well. If you're spending money on rods though, you're better off using K20 pistons and custom longer rods.
rny
Ok, how much more effect will it give?
rny
Or what do I win or loose when I’m going for 88 mm crank with S16 Pistons?
SRDT
9 hours ago, rny said:
XUD11 88mm crank
XUD9, the XUD11 crank is another beast.
You can also look for a 2.0 HDI crank:
Increase capacity from 1998 to 2044cc.
Increase CR from 10.8:1 to 11:1
Thus more torque and more power everywhere.
Richie-Van-GTi
Sorry to hijack, what are the options if I have an 88mm crank from a diesel but cant find the s16 rods and pistons? Can i buy some other rods and retain the std pistons or retain the rods and buy other pistons etc? What height difference do I need to reduce by?
This is how I see it. Others may have other opinions.
XU10J4RS Pistons & Rods
Rods are 158mm long and have a pressed pin. This makes them a pain to disassemble and re-assemeble. You could bush the small end, but it would be a smaller diameter and require custom pistons. If you condiser the cost of bushing and new rod bolts, you may as well bought new rods. The pistons have very shallow valve pockets, so you need to spend money getting that altered anyway, if you want to make any sort of decent hp. Once they're out of the engine, you may as well buy new pistons, unless you want originality. Comp height is 34.
XU10J4 Pistons & Rods
Rods are 152mm long with a Ø23mm full floating pin. They're easy to re-assemble. The pistons have deep pockets which can accommodate around 0.070" lift at TDC when used with an 88mm crank. Again, once they're out of the engine, you may as well buy new pistons, unless you want originality. Beware that Wossner only sell them with Ø22 pins. Why? Who knows. Comp height is 39.1mm.
My advice is to find some XU10J4 rods (I have plenty) and buy new Wiseco 86.5mm pistons from Flatlander. That will be cheaper than K20 pistons and custom rods. Assuming you're not building a race engine.
Block height is 235.1mm. Thus
43 + 152 + 39.1 = 234.1 (oem)
44 + 152 + 39.1 = 235.1
43 + 158 + 34 = 235
Edited by petert
I agree with Peter, find a piston you can make work, get a rod made to suit
Beware of the wossner stuff, certainly their gti6 piston is way off their stated compression ratio, its almost as if they took the S16/mi piston and adjusted the pin height only, it has to be why so many dont make good power or last long, they ping their tits off from running so high a compression figure unless you have a good mapper.
Edited by welshpug
Richie-Van-GTi
Shopping about and looks like i wont get anything under £600, been a while since i looked into these kinds of things. Seems to have got a lot more expensive.
Sounds about right, my robson rods were £580+vat a few years back.
I dont think stuff has gone up that much.
Tseize
Posted (edited)
I guess the XU9J4 crank would not be adequate without changing anything else on a genuine XU10J4 ACAV. Or would it be?
Edited by Tseize
The XU9J4 crank is a direct swap. You just need to check the bores are not worn, as the top ring will travel another 1mm further up the bore and thus probably break.
  • Thanks 1
Tseize
Would the valves hit the piston in case of using the XUD9TE crankshaft with ie. Cat Cams 4912526 ("sport") on XU10J4 ACAV without any further cut on the pistons?
According to Cat cams the valve max. lift is for 9.2 / 9.15 mm (inlet/exchaust) for the original cams, while their "Sport" has got a 10.75 / 10.25 mm valve lift.
you will need to check, the valve cutouts are quite large but moving them up 1mm moves the edge of the cutout closer to the valve as well.
It’s not the max lift that matters. It’s the lift @ TDC figure that you need to worry about.
The lift at TDC for the oem inlet cam is 0.032". There is 0.205" of gross space, between valve and piston, oem. The 4912526 inlet is supposed to be installed at 1.45mm (0.057"). However, that is too retarded and should be more like 0.090". Subtracting 0.205-0.090 = 0.115". If you push the piston up another 1mm (0.039"), you're left with 0.076". You'd possibly get away with it. I'll get some pop corn.
