Joeygardiner12
Engine rebuild HELP !!!
Joeygardiner12
So im currently rebuilding my 205 gti 1.9 XU engine but in comparison to other rebuilds ive done there seems to be a massive lack of technical information in the manual. Theres no information for camshaft bearing clearance. The manual just states to visually inspect the journals and caps.... no runout specs, endfloat or anything. Same goes for valves it doesnt state what the valve guides should be or their wear limits, doesnt state the valve stem wear limits either. Just says if you can wiggle them too much then replace them. How much is too much :unsure: i need numbers !
Leslie green
The exhaust valve guides are the ones that wear so id just replace those no matter what  , i got mine replaced and the engine shop said the inlets were fine and as for the cam bearings they run in the head so not much you can do if they are worn really is there plus they are line bored so you can't just put one of another engine in although in reality id imagine they are very close .
Finding someone to tunnel bore a head in Australia is becoming a thing of the past. Very few do it any more.
One thou per inch is fine on the crank. If the cam still turns, it's good to go.
Edited by petert
Thijs_Rallye
I hope this will help.
Dimensions are in [mm], inlaat = intake, uitlaat = exhaust, nominaal = nominal, 1e reparatie = 1st oversize, 2e reparatie = 2nd oversize.
Joeygardiner12
Thank you so much mate, to both of you two! Is there also any information regarding big end and small end dimensions ? I am currentley looking at a german manual on ebay which looks like it could be the one you have kindly shown me !
Surely there should still be a wear limit standard to the camshaft/cylinder head otherwise how would a mechanic know when it would be time to replace it aside from visual inspection ?
Thijs_Rallye
Yes, I will try to remember tonight and snap a few pictures. If you need anything more then please reply to this post :).
I've just had a look through the Haynes manual downloads on 205gti.com
I think the Chapter_02d_Engine_removal_overhaul has the info you're after.
g
Thijs_Rallye
Rods:
IMG_20220506_200457.thumb.jpg.727607d5f45320a621ec3436e82560f9.jpgIMG_20220506_200510.thumb.jpg.35ada2d5d9a973f434afdca41f55000b.jpg
Thijs_Rallye
Crankshaft main bearings and rod bearings:
The lined note states that the big end and main bearing surfaces need to be polished after grinding.
The bearing size diameter is indicated at face E, where yellow (= geel) means between 59,981 <= ØB < 59.990 and green (=groen) means between 59.990 < ØB <=60.000
I can't find the equal or greater to and equal or smaller than sign on my pc for some reason.
IMG_20220506_200518.thumb.jpg.169cb2da6feeed79d0bee47a0eb951b5.jpgIMG_20220506_200528.thumb.jpg.ec80544e762b59701bed912a8ae0aee0.jpgIMG_20220506_200546.thumb.jpg.a0e17d9ac43a9db4097007dbc7b3ffce.jpgIMG_20220506_200536.thumb.jpg.08742c738befefb60ec1d5ff33d691b0.jpg
Edited by Thijs_Rallye
Thijs_Rallye
The forum is giving me a hard time uploading it all. Rearranging pictures is a bit of a nightmare (reminds me of word), so I hope you will figure it out.
Bearing sizes (thrust) and big end bearing sizes.
Top bearing shells are all the same size, clearance is set with the bottom bearing.
Classes of the bearing shells are determined by the big end and / or main bearing diameter.
Running clearance of the bearing shells is between 0,038 [mm] and 0,062 [mm]
IMG_20220506_200652.thumb.jpg.877370fc8e990fe27162ece4e3f42876.jpgIMG_20220506_200625.thumb.jpg.83a5e56bc6d3a7bf211e477202b78787.jpgIMG_20220506_200618.thumb.jpg.aede2f7e174cee32571d9f832b6327bd.jpgIMG_20220506_200612.thumb.jpg.e885e57fc2500cf03eba2b2d7593e652.jpgIMG_20220506_200607.thumb.jpg.f83cb08c6d2f00e8513a14e87b8398f0.jpg
Thijs_Rallye
Circled note: do not reuse the rod nuts but use new ones.
Klasse A = class A = blue
Class B = black
Class C = green
Class D = red
Onderste lagerschaal = bottom bearing shell
IMG_20220506_200739.thumb.jpg.861bf7f3c5693b5ecf7027ef3d4ccf3b.jpgIMG_20220506_200723.thumb.jpg.0079a3093f923af91ef202cc07a39b29.jpg
added a bit of translation
Thijs_Rallye
IMG_20220506_200703.thumb.jpg.b2dea8010ff360edad7eedfecbdbfc80.jpgIMG_20220506_200659.thumb.jpg.8ac75790987ad167d3d3a6a62c75f497.jpg
Joeygardiner12
Thats the haynes manual i have, it sadly doesn't state any dimensions for the connection rod big end and small end diameter. And thanks so much for all the pictures i now have the task of trying to read german haha,  i will post some pictures up of my rebuild. Yes i have read up on the bearing shell procedure strangley i cant find any barcode on my engine block or crankshaft which is strange.
If you could dissect the german for me i would be most grateful, i need to know
connection rod big end and small end standard wear limits
valve guide standard and wear limit
valve steam wear limit ( upon measuring my exhausts i think i had a difference of 00.02mm from top to bottom ) so hopefully they are still usable.
Thijs_Rallye
  On 5/7/2022 at 8:52 AM, Joeygardiner12 said:
german
Dutch ;)
The pictures and tables speak for themselves really, the interesting bits have been translated already in those posts.
Worst case you will have to re-type some words in google translate. https://translate.google.com/?sl=nl&amp;tl=en&amp;op=translate
Joeygardiner12
  On 5/6/2022 at 6:15 PM, Thijs_Rallye said:
Rods:
Okay so say here for example it says nominal ( normal ) size for big end diameter. Is the +16mm oversize the limit on how much wear i would be allowed.  So for example 61.855 would be the max wear limit. Sorry its usually worded very different in English manuals. And ah dutch ! Fantastic country , cycled it all many years ago
DamirGTI
I've the same book as above in English ... if you cannot decipher Dutch .
D
Thijs_Rallye
They state the standard sizes with a tolerance, so the rod big end diameter is 53.695 mm (DKZ) mm, which is the nominal size. Everything machined has a tolerance, so the size in this case can be +0.013mm but not smaller. I agree it isn't the most clear way of indicating.
The nominal big end journals diameters are 50 +0 -0.018mm
To determine if it needs to be ground you will have to measure the diameter of the big end journal and calculate with nominal bearings if your running clearance is within specification. Nominal bearing size for the DKZ is 1.833 ±0.005 mm.
Joeygardiner12
Thank you so much for all your help. I will measure the rod big ends up tomorrow. Still need to determine how to find out what size bottom bearing shells i need as theres no barcode on the block or crank. I still have all the old bearings. Im pretty sure they have codes on so i could plastigauge them and if they are within good tolerence just replace them with the exact same ones, there was very minimal wear on any of the crank main journals only 00.01 or 00.02mm diffrence on one or two of them.
Also it may be a language difference but just to make clear do you mean 00.13 should be the wear limit for the connection rod big end.
53.695 standard machined size , the max amount of wear they can have is 00.13mm.
Thijs_Rallye
No, that is the machined size when it was new. So anything between 59.695 and 59.708 mm is considered within in spec as it left from factory. They do not give a specific wear limit afaik.
So you will have to measure it all, take new bearings in consideration and calculate the running clearance. If you cannot reach the specified clearance you will "have to" grind the bearing journals to the first undersize.
Tbh, it might be a better idea to have a professional measure the crank, since Peugeot doesn't specify roundess either and most engine rebuild shops have loads of experience and have a pretty good understanding of what is ok and what is not.
Joeygardiner12
No worries thanks so much for all your help. I have measured the runout and endfloat and they are both spot on, with the crank journals all having minimal wear i will feel okay installing it. Just have the joyus job of having to helicoil one of the head bolts first. Then i can measure up the bearings needed and get on rebuilding the bottom half.
