driversdomainuk
Omex 200 set up
driversdomainuk
Hi All
I’m upgrading to Omex 200 ignition only set up. My 8v 1.9 is currently on Weber carbs.
I need to buy the parts in advanced and want to make sure I get the right bits. Here’s my list so far, with a few questions:
1. The Omex 200 ecu (obviously!)
2. TPS for carbs
https://www.ebay.co.uk/itm/Omex-Throttle-Position-Sensor-Kit-For-Weber-40-45-DCOE-Carbs-For-ECU-Input-ADV-/273955627926?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&mkrid=710-127635-2958-0
3. harness (think this is the right one?)
https://www.ebay.co.uk/itm/Omex-200-ECU-Basic-Road-Harness-SPOOX-MOTORSPORT-/334109726085?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&mkrid=710-127635-2958-0
4. Crank sensor - I assume a standard one for the 1.9 is fine?? I don’t know if mine is there still after it was switched to carbs
5. Coil pack? Any ideas where to get?
6. custom made HT leads - again any ideas who can provide these?
Anything else?
Rob
SRDT
Was your 1.9 a D6B with Jetronic or a DKZ with Motronic and cat? Only the DKZ has the right flywheel to use a crank sensor.
As for coil pack and HT leads there should be a way to use Peugeot parts from a XU with coil pack.
driversdomainuk
It’s an 89 model with no cat, so I assume D6B. I was told maybe an Mi16 crank sensor would work, or at least that would be one option.
You'll need either a DKZ or the larger XU9J4/XU10J4/XU10J4R/XU10J4RS flywheel, if you want to use a 60-2 crank sensor. The larger flywheels are a dime a dozen and it's easy enough to convert to a 1.9L Mi16 clutch.
Edited by petert
SRDT
A 200mm flywheel from a XU5M, XU5JP or XU7JP can also do the trick.
driversdomainuk
What ht leads will be best?
SRDT
Something out of a 8v XU with a coil pack, watever is more common and cheap.
Citroen Zx 1.9i leads and coil pack are what you need
