Kambo
Std Power Steering - do you have to have the hard line sections?
Kambo
Hey
I removed my original power steering setup when I took the engine out a while back but had trouble removing one of the fittings on the pump so the fitting was butchered a bit to get it off, will get a place to make up some new pipes for me but
I think I remember there was a couple of hard line sections on the long pipes which I’m guessing is to make the bends around the engine/gearbox, but is this actually required for replacement pipes? I would rather just take the pump along and say a I need xxx long pipes made?
they aren't absolutely necessary however flexible pipe will be far more bulky and unable to take the tight radius bends a hardline could.
Mine is flexible, other than the last 20cm or so where it goes into the valve body. The hard line cooling loop is still there. I should also add mine is 16V, so a lot shorter. I think it needs to be hard for the sharper corners in an 8V installation, as Mei suggested.
Edited by petert
Kambo
Does  the actual length of the pipe matter for efficiency ie finding my own custom route?
Its a standard 1.9 bay setup so some room to play around with...
Nope. I switched to flexible because the pipe fatigued at the pump (S1 Mi16).
Kambo
