Biggles
306 vs 205 1.9 hubs
Biggles
Can someone tell me the exact change in camber you'd get swapping 306 hubs for 205 1.9 (changing nothing else) ?  I know the 306 ones give you less negative but by how much ?
Thanks.
306 hubs give about +0.75 deg on a 205 from memory
iirc standard is -0.16.
allanallen
There’s 1.3 degrees difference between a 205 and a 306 hub, the latter giving positive camber on a 205.
That figure is from accurately measuring hubs, they give varying amounts of camber when  actually fitted to cars, some folk have reported nearly 2 degrees of positive where as some have as little as 0.5 degrees!
Biggles
Excellent, thanks.
