katmav 0 Posted July 2, 2017 Hi, does anyone recognise this drivers side electric window regulator? Looking for a fix as the cable has snapped, motor still works fine. Doesn't look like any of the ones I have seen up for sale...car is a 1.6GTi J reg. Share this post Link to post Share on other sites
pugdamo 111 2 Cars Posted July 2, 2017 That's an aftermarket set up, not sure how you would go about finding a replacement though, I'd try getting a standard electric reg and fitting that, may have to modify the wiring depending on what's already been done though . Share this post Link to post Share on other sites
Tom Fenton 1,564 Posted July 2, 2017 The motor and drive cables are aftermarket, the mechanism is standard windy window with a bit cut off and the cable drive thing attached! As said it's some kind of aftermarket conversion kit that uses an electric motor to turn a windy handle spindle! Easiest way is a proper 205 electric mech which will bolt straight into your door. Wiring is 2 wires the worst you can do is get them the wrong way round so it works backwards and have to swap them over. Share this post Link to post Share on other sites
Slo 283 1 Cars Posted July 2, 2017 I've just bought one of those kits http://www.ebay.co.uk/itm/Universal-2-Door-Power-Window-Kit-Electric-Roll-Up-Conversion-w-2-Swithches-Car-/322465796345?hash=item4b147590f9:g:RvcAAOSw4A5Y2jo7 Doddle to fit too Share this post Link to post Share on other sites
steve@cornwall 100 Posted July 3, 2017 That's an aftermarket set up, not sure how you would go about finding a replacement though, I'd try getting a standard electric reg and fitting that, may have to modify the wiring depending on what's already been done though . I believe I have a pair of those! Have thought about using them on CTI dear windows but don't think it's worth the hassle. I had them fitted in a previous CTI ( at the front) and are not hard to fit Share this post Link to post Share on other sites
katmav 0 Posted July 3, 2017 Thanks all, that explains it! Share this post Link to post Share on other sites
VDU 0 Posted July 3, 2017 Hi Matt, I have just removed one of these. I will need to test it still works but you are welcome to have it for the price of postage. Andy Share this post Link to post Share on other sites
Slo 283 1 Cars Posted July 3, 2017 Have thought about using them on CTI dear windows but don't think it's worth the hassle. That's exactly what I have bought them for, only problem is deciding how to mount switches and where considering the rear passengers will also need a switch too. The switches that come with them are horendously cheap looking Share this post Link to post Share on other sites
steve@cornwall 100 Posted July 4, 2017 Mount them in pairs in front and behind handbrake? I was thinking a pair of single switches in the rear and a single switch in front to lower all 4 windows with one touch. Share this post Link to post Share on other sites
