flyfisher 6 2 Cars Posted June 8, 2017 Hi I've just tried to replace my front windscreen wiper moter as old one was very slow. Put it all back together big problem now wipers stop half way up screen I used a 106 wiper moter I was told these are a straight swop. ? Any way I then put old wiper moter back in just in case they might be different but I've still got same problem when turned of they stop half way up screen any idears? Is there a set up procedure it must be something I've done. Any idears Share this post Link to post Share on other sites
welshpug 1,682 Posted June 8, 2017 you need to move the arm on the motor to the appropriate position. Share this post Link to post Share on other sites
flyfisher 6 2 Cars Posted June 8, 2017 Many thanks is this a matter of trial and error as that arm on moter can go any where Share this post Link to post Share on other sites
Anthony 1,003 Posted June 8, 2017 Yep, as Mei says - you've attached the arm onto the incorrect position/angle on the motor. Chances are what you did was move the arm from the old onto the new motor in the same position, but the new motor wasn't in the park position so it moved. Check the state of the linkages/spindles as well if you haven't already done so, as often the slowness issues stem from the spindles rusting and seizing up rather than the motor. Share this post Link to post Share on other sites
flyfisher 6 2 Cars Posted June 8, 2017 Many thanks anthony Share this post Link to post Share on other sites
harryskid 193 Posted June 8, 2017 Are new 205 ones available? Share this post Link to post Share on other sites
flyfisher 6 2 Cars Posted June 9, 2017 Don't know about new but pug 106 moters are the same Share this post Link to post Share on other sites
