Gaz205
Wind Noise
Gaz205
I can find plenty of threads on water leaks... Not many on wind noise.
After a respray, my car has quite loud wind noise. Pin pointing it to the doors rather than the screen as this seems louder. Are the main seals preventing wind noise the actually rubber door seal or the rubber that runs along the roof edge down to the wing? I have ph1 mirrors on ph2 doors which took some adjustment, are these likely culprits based on exprerience?
I'm keen to start taping up here n there and spraying water but just wondered if there are any 'common' adjustment to make or likely culprits to aim at first before adjusting doors and pulling and peeling seals again
Thanks in advance
Henry Yorke
I find I get some wind noise on my passengers side door mirror. Not rectified it yet. Sounds a good idea to tape where it fits to the door and see if this stops it
Gaz205
I didn't know the mirrors mount differently so may have to upgrade my mirrors. Magic tape for now, thanks for that
Telf
Gaz,
Wind noise, its part of the 80s charm....
pugdamo
I get a little wind noise from the tops of the doors at around 70mph ish, if i put my fingers on the seal of the glass at the top and pull the door in slightly it stops, it's never bothered me enough to fix it though, maybe yours is the same place?
steve@cornwall
Do you have electric windows? I find that when mine go fully closed they deform the tops of the doors somewhat.try just dropping the window a gnats
pugdamo
I didn't originally but I do now ????. The noise for me was there with and without posh windows.
Lower window glass. Open door brace the bottom of the frame with your knee and give the top a gentle tug inwards. Obviously go steady!!
But this should pull the door in tight to the rubber and stop the noise.
Gaz205
  On 6/4/2017 at 4:26 PM, Telf said:
Gaz,
I thought that was just the clunks and creaks?! It wasn't there before n it's bugging me now. Il
Gaz205
Good old fashioned windey Windows
Tom, That sounds pretty dam scary. Especially as I had to beg to buy the replacement doors to put on the old girl.
However, I'll give it a go after I've re applied adhesive to the strips on the door frame if that fails, which I think it will as the top is pretty saggy
As long as you are not a chimpanzee then it's easy enough. It's only what Peugeot would have done in the first place!!
Gaz205
No pressure there then ????
steve@cornwall
You could also try adjusting the latch striker to pull the door in.
Gaz205
Done that one and it's perfectly in line with the rear quarter. Nipped it a little past but anymore makes it look a bit silly.
I'm gonna give toms idea a go when I next go in the garage if the rain ever stops!
