DrSarty
Xmt - Sarty's Xsara GTI6 Turbo
DrSarty
And will one of the mods PLEASE change this topic title to GTI6 instead of Mi16.
It should also be 'Xsara XGT' as a result.
There is nothing Mi16 about this build, other than it probably being an ancestor of the GTI6. Plans changed... as they do.
It's a GTI6 block (bored out), a forged diesel crank, a GTI6 inlet & a modified GTI6 head, bolted to a VTS 'box (with Quaife). From an engine perspective, everything else is custom. It's barely even a GTI6!
Edited by DrSarty
Done.
g
DrSarty
Thanks G.
Questions: I've never really understood why some cars have a vacuum pump. They are typically run off the end of a camshaft. I've removed mine from all of my Naturally Aspirated (N/A) builds as the vacuum/servo assist has always come directly from the inlet manifold & I've never had an issue with braking assist.
1. Why are they used, especially on N/A cars?
2. IF they were there explicitly for Forced Induction (F/I) cars - turbo or supercharged - which clearly they are not, I'd perhaps understand it, as PERHAPS the manifold pressure situation is different on F/I cars. But as this engine is turbocharged, (a) do I need a vacuum pump & (b) if not, how do I supply vacuum to assist the servo?
I'm sorry if this is a dumb/already covered question.
EDIT: Started to do some research. I think I'm going to get & use an electric vacuum pump:
  • This video plus some useful text below
Edited by DrSarty
DrSarty
It's ALIVE!
10+ years in the making, although most assembly work has happened in the last 2.
It started first time, but of course there are stories about that & the busy build work of late. Detail & photos to come.
Here's the engine bay as it stands. Some final wiring tidy up work to do soon (bottom right & top right).
Huge thanks go to Goliath, Welshpug & 'Jez' (don't know his forum name, but he's finishing a 405 V6 in the same workshop), & numerous other contributors too many to mention.
It sounds mean, like a WRC car on the start line. Lots of further setup & mapping to come, but it should be on the road soon.
Summary/reminder of the build:
- GTI6 head
- 87mm bored 2.0L block
- Forged crank, rods & pistons
- 2.3L capacity with 9.3:1 CR
- Inconel (sp?) valves
- Some porting & flowing
- Custom, equal-length runner exhaust manifold (wrapped)
- Custom, stainless full exhaust post-turbo (some ceramic-coated)
- Owen Developments ball bearing turbo
- Turbosmart wastegate, oil & fuel pressure regulators & blow-off valve
- Quaife ATB
- Emerald K6 ECU, with wideband lambda & custom loom
- Custom fuel rail & 846cc injectors
- Modified Nissan 350z intercooler
- Mocal oil cooler
- Volvo vacuum pump
- Saxo 50mm thick rad with twin Spal pull fans
- Already has the lovely 2.3 turn VTS quick rack with hydraulic PAS
- 4 port electronic boost controller
- Added boost & oil pressure gauges
I'd also like to hand out big cheers of admiration to anyone who has done or plans to do something like this, especially with a high degree of customisation. Even adding a turbo or supercharger via an off-the-shelf kit is quite a big job. Hats off to anyone who's crazy enough to do things like this.
Hopefully 400bhp & similar - if not 20% higher - torque figures will be achieved. But at least it runs already & is ready for final steps including mapping.
Edited by DrSarty
Corrections
  • Like 3
Jer309GTi
Can't wait to hear it, glad you've got it going! (I'm the one with the 405 v6)
Passenger ride when it's on the road please! :D
Are you using a BE or ML gearbox? Reason for asking is from a lad we know with a GTI6 turbo, you'll almost certainly destroy a BE at that sort of power output. In particular 5th gear is really weak due to its position hung off the end.
DrSarty
It's a BE, & I'm aware it may be the weakest link. We'll see. Plan is not to beast it so it breaks, ie a settling in period.
I'll look into ML replacements & hopefully do it as a proactive swap, rather than a fix next year.
Lots of/lots more travelling to do this year!
Last year I visited 30 countries (including 26 in under 80 days). Next week I'm doing a 500 mile walk across the Pyrenees, then later in in South Korea, Vietnam & Australia.
I need to find some time in late 2025 to drive the bloody thing!
Well done. I'm wondering if you'll max out the 846cc injectors? Which of course means it's making HEAPS of power. Don't forget to call in
Ron_Jaegers
Really cool build this! Can't wait for video and audio.
If you travel that much and plan to stop in the Netherlands maybe you can take over my ML6c (20mb04) gearbox. Should be plenty strong to handle serious power. Caveat: it's now mated to an EW and will need customisation to get it to work on a XU. But the experts here might be able to help.
Good to see these projects being finished. Gives me hope I will once finish mine as well.
stef205
id say the opposite, a quick calculation would say roughly only 600cc is needed for 400 horse. Our 550's are over kill at 400 horse
DrSarty
PeterT - Defo. We missed each other last time I was in Sydney, so let's make sure it happens this time. It'll be from July 8th to early August. Maybe meet in the Bavarian beer place again?
Ron - Yes please!!! The Dutch contingent here are a great crowd & with Goliath/George, I have quite a lot of contact. Stayed at 'Sander's' place recently after driving an M3 over.
Stef - I'm inclined to agree with you, ie not use over 800cc/min, however some online calculators indicated I'd need close to that. I thought about 600, but when some calcs showed more than that, plus people saying modern injectors of 1000cc+ still give good low rpm resolution, I thought I'd go big to be safe.
Thanks for the comments.
SRDT
Excellent choice... but maybe I'm a bit partial here.
As for the ML6C it exist with the correct bellhousing pattern but your engine will then lean at 18.5° to the back instead of 30°. Oil pump pickup and oil pan can be sorted using 2.0 HDI parts but there is a lot of stuff to move around in the engine bay.
I was thinking E85. Very popular here now.
Anytime after 10 July suits me. Or that gin bar?
DrSarty
Dunno if this'll work. Wear good headphones or use decent speakers please.
  • Like 6
wicked
On 3/10/2025 at 8:41 PM, DrSarty said:
It's ALIVE!
Congrats! Epic milestone in a build like this. My longwinded engine build did its first start this winter as well and it's nerve-racking due to the yrs waiting...
When will it be mapped?
pip470
Yes Rich. That looks incredible. I’ve just enjoyed catching up on the progress and hearing George, Dan and Mei are all helping out. That’s just awesome. Would be good to see this in the flesh at a meet one day. Keep on with the good work.
Leslie green
Well done on getting it running .:D
DrSarty
I'd like to provide an update..... if anyone is interested.
Life as we all know with projects, gets in the way. But we always come back (well... pretty much always).
These things have to be finished, problems overcome & the dream realised. What we've dreamed of & toiled over, spending silly money on quite often, needs to be driven.
Moreover - despite moments where we feel like walking away - the opinions, support & technical input from many wonderful people needs, to be reflected & perhaps rewarded by damn well delivering on the plan.
I felt like giving up after it was first running (& I was happy), when a deburring tool (a die grinder) which was somehow lodged & hiding in the exhaust manifold, found its way into & trashed the turbo!
Bollocks!
Fortunately.... the wonderful people at Owen Developments felt my pain. I removed the turbo, sent it to them, & they fixed it FOC.
Yesterday, after many adventures in countries like France, Spain, Andorra (ahem... driving heaven!), Gibraltar, Morocco, Belgium & the Netherlands - plus Ethiopia & Zambia for a new job - I/we refitted the turbo & the Xsara fired up again.
And it literally 'fired up'!
After running it for a while & standing next to it with George (aka Goliath), a small fire erupted at the rear, above the exhaust!
Double bollocks!
George ran off, grabbed a CO2 extinguisher (because powder would've made a mess) & we salvaged the situation. We were confused, because all hoses were clear of hot bits.
With a camera, we found it was just a piece of rogue rubber hose offcut hiding in the complicated exhaust manifold which had got hot enough - after all this time - to ignite.
It's run now since first start for about 1 hour cumulatively; but today was the day that debris decided to catch fire.
Better here & now than on the rolling road eh?!
Then we found it had cranking issues (battery related), is it kept going flat & wouldn't crank.
I'd already put on a new battery & made sure the ground was good.
Then I spotted that the main battery cable ring connector - to the battery in the rear - was a bodge....by me... so I replaced that.
Recharge the battery. Great... it's 12.8v. It starts again. Hooray! No fires or leaks. Back on cloud 9.
But then the battery is dying again. Why? The battery light isn't on. Let's check the alternator.
19.8v output! Seriously. F**k off car - I'm done with your games!
LESSON: Always check your components before you fit them, especially if they're a b**tard to replace later.... like my alternator!
Inlet manifold off, lots of connectors, grazed wrists, knuckles & swearing, & the alternator was removed. It can go off for rewinding & PROVING now, ready for a pain in the ass refit.
On the plus side....I could tighten up the loose starter motor bolts (idiotic oversight), tidy up & shield all the wiring & generally titivate the engine bay. I also fitted a heat blanket on the turbo.
So.... we push on right? WE NEVER GIVE UP.
Mapping soon. Aiming for 400bhp & 450 'torques'.... if I'm lucky.
  • Like 7
DrSarty
The aforementioned foreign object entering the turbo. (Aaaaarrrggghhh!).
But nice dash gauges for oil pressure & boost.
Also - & perhaps weirdly & opening myself up to criticism, like I care, as all who know me will testify - the 13 speaker sound system works perfectly & is banging!
DrSarty
I'm going to say it again, because it's more important than the correct parts at times.
PEOPLE. SUPPORT. ENCOURAGEMENT. ADVICE FROM CLOSE OR AFAR.
This is what keeps projects alive at times.
So although this website forum format is probably dying - let's be honest - I think there's a parallel with older & challenging project cars & this channel. It's perhaps a better or the best 'forum' where people who have interests & can thrive, show interest, research & provide input can operate.
Yes... it's clunky... but it works.
So DO NOT LEAVE! Stay subscribed. Follow. Make the effort. Don't abandon this way of communicating.
Support lunatics like you.
The world needs lunatics like us.
What we do is fantastic!!!!
  • Like 3
wicked
Yes! Still interested!
DrSarty
Yay!
A response. Thank you.
You guys are out there.
So... let's build on it.
Look out now, for the following idea...
A new thread will follow.
It's called 205100.
Definitely still interested. Sorry about the time difference for checking in. There aren't many people on here these days, but we do care.
Get on with it! I'm so looking forward to seeing the dyno graph.
chris 417 mi
Following with interest :), we need to keep these forums going ... facebook just isn't much good for looking for old tech specs / data etc ... this definitley is !
