Staffyed
Washer Pump Voltage Issues
Staffyed
Hi Guys, got a weird electrical problem related to the washer pump. 205 CTI.
checked pump on battery and OK.
with pump connected wipers do not operate.
without pump connected wipers operate
with pump connected getting 6 volts on fuse board output to pump and 12 volts when activated.
bypassed wiring loom by connecting pump straight to output from fuse board and to the negative on the battery - the same.
Could it be the wiper control relay (big blue one)
any help would be appreciated......
toolie72
Wiper stalk/switches ok? Does sound almost like a back feed from somewhere
Tried tapping relay with a screwdriver whilst trying to run everything (works on passenger lifts haha)
Staffyed
found fault,was the stalk and a bad connection so getting a double issue. All good now.
