steve@cornwall 100 Posted September 5, 2016 I've seen these advertised but have no idea how to fit them. Are they fitted with a pop riveter or do they need a special tool? If anyone has done this would be interested in your experiences as I have a very good base model door, stripped bare and primed which I may paint for my gti. If it's a bit of a faff, I'll deal with the couple of dents and distortion around the door handle on mine. I won't be self tapping the trim on! Share this post Link to post Share on other sites
Duroc 2 1 Cars Posted September 5, 2016 I did mine with a standard pop riveter. Worked perfectly Share this post Link to post Share on other sites
mrfirepro 127 1 Cars Posted September 5, 2016 I used these part of this kit Used standard rivet gun to put them in, if you don't want to take apart another door, I have a stripped down door here I can take measurements off if it helps. Share this post Link to post Share on other sites
steve@cornwall 100 Posted September 5, 2016 Thanks both, looks like the eBay kit is the way to go. Paul, thanks for your kind offer, I have a spare pair of cti doors I can take templates from. Share this post Link to post Share on other sites
welshpug 1,678 Posted September 5, 2016 (edited) if you have all the clips, then I have vague memory of a Vauxhall Calibra using the same rivet, and they may be available form someone like Wurth, Miles might recall more. OOH, found these, they look god, need to measure to make sure. http://www.bresco.com/acatalog/Moulding-Clip-Rivet.-Ford--Vauxhall-and-general-application.-BSF527P.html Edited September 5, 2016 by welshpug Share this post Link to post Share on other sites
dobboy 231 2 Cars Posted September 5, 2016 Yeah calibra ones work, and VX had them when ii checked couple of years ago Share this post Link to post Share on other sites
steve@cornwall 100 Posted September 5, 2016 Wow, thanks Mei and Jack. Have a vauxhall dealer about a mile from work, too. Share this post Link to post Share on other sites
GazMav 3 Posted September 6, 2016 The box of bits: 6994 44 is still available form the dealers, so might save a bit on the ebay ones. Share this post Link to post Share on other sites
steve@cornwall 100 Posted September 7, 2016 if you have all the clips, then I have vague memory of a Vauxhall Calibra using the same rivet, and they may be available form someone like Wurth, Miles might recall more. OOH, found these, they look god, need to measure to make sure. http://www.bresco.com/acatalog/Moulding-Clip-Rivet.-Ford--Vauxhall-and-general-application.-BSF527P.html Thanks Mei, ordered! Share this post Link to post Share on other sites
stumpyjag 6 Posted April 2, 2019 On 9/7/2016 at 6:59 PM, steve@cornwall said: Thanks Mei, ordered! Hi did these fit ok?? Thanks. Share this post Link to post Share on other sites
steve@cornwall 100 Posted April 3, 2019 Afraid I didn't use them Share this post Link to post Share on other sites
stumpyjag 6 Posted April 3, 2019 Is that because they didn’t fit? Share this post Link to post Share on other sites
steve@cornwall 100 Posted April 5, 2019 On 4/3/2019 at 8:25 PM, stumpyjag said: Is that because they didn’t fit? It's because self tappers through the clips were easier! The door was taken out by a blind taxi driver and I fitted the replacement door in a hurry to keep the car useable. Since been replaced with a good gti door so weren't needed in the end. Share this post Link to post Share on other sites
