Simes
Picked This Up Today (Griffe Content)
Weser
Is that no radio? Also no Air con - I just presumed they would have it.
Weser
Centred map reading light + no sun roof?
The only odd thing I could see at a glance was that both drivers and passengers sun visors are illuminated and have mirrors, unlike UK cars, but I'm guessing it's not that obvious?
Edp
Something to do with the illuminated visors I reckon...
dcc
Pretty sure the gentry had the same mind
Simes
Yep it's that obvious.
I'd never seen them before.
j_turnell
Yeah came stock on the Gentry and STDT, Pretty sure I've got a set kicking about somewhere.
Pugleyrich
I've got a set. Dyed them grey using plasticare because the gentry had light grey/beige headlining and roof plastics. They are a nice little upgrade
Did they have heated mirrors as well?
allanallen
Back to front coin tray is twisting my melon man! :P
2-Pugs
Yes, Miles you're right, they did have heated mirrors.
There's a couple of other interesting points of note too. The steering wheel has green stitching in place of the usual black.
The weirdest one of all, is that when the drivers door is open, even with the key out of the ignition, the electric windows work!
It was essentially a halo/run out model for the 205GTI, apart from aircon it has some nice additions to it.
Nice looking mag though Simes!
STDT's are like that too, possibly Gentry's as well.
Pugleyrich
Yep, Gentry's also do that. I'm not sure if it's normal, but mine doesn't do it with key out but door closed - you have to open them with the key out to close the windows (or put the key back in)
GLPoomobile
I thought the unusual thing was the working coin tray lid. Well, i assume it was working anyway!
2-Pugs
Well, never knew that about the STDT & Gentry! Learn something new every day :-)
Edited by 2-Pugs
Handy thing to have with the windows on the Gentry's along with the mirrors, 405's had the same set up, well the Mi's did from 1991 facelift, The 1FM's must have the same thing surely? bit odd if not when everything else was added on
Pugleyrich
Miles - did the heated mirrors on your old Gentry work when you had it? They don't now, but I wondered if they had been changed over at some point
yorkshirekowboy
Are the illuminated visors a plug and play to the gti with no cutting of wires etc?
j_turnell
You just need a live an earth for each. They are on bullet type connectors as standard iirc. Took mine out and dyed them black and never got around to refitting. Not sure where it gets its earth and live from though, but easy enough to do without the loom. I may refit them at some point!
Henry Yorke
It must take the power from the interior light I reckon and the wires run along the inside of the head lining
