barneys66 125 1 Cars Posted April 29, 2016 Had a local quote to powder coat my bare subframe for £90. Does this sound a bit rich, or am I just being unrealistic / tight..? Share this post Link to post Share on other sites
calvinhorse 870 Posted April 29, 2016 Sounds a lot.. I've paid £30-£40 in the past 4 wheels are £100-£120 where I go and that's blasted and coated Keep shopping about, cash goes a long way Share this post Link to post Share on other sites
allanallen 528 2 Cars Posted April 29, 2016 The place I use would charge max £30 to blast and coat a subframe. Share this post Link to post Share on other sites
Juttie205 123 2 Cars Posted April 29, 2016 Seems expensive Share this post Link to post Share on other sites
allye 530 3 Cars Posted April 29, 2016 Yer that's way too much. Share this post Link to post Share on other sites
barneys66 125 1 Cars Posted April 29, 2016 Thanks guys - I was expecting £40 max, so good to know I'm not out of touch..! The search continues.. Share this post Link to post Share on other sites
Juttie205 123 2 Cars Posted April 29, 2016 If you were willing to travel i used mastercote in norwich. 1 Share this post Link to post Share on other sites
Miles 331 1 Cars Posted April 29, 2016 it varies allot, Having 1 item will not help at all, I know my place charge a set up cost so the more done the cheaper it is Share this post Link to post Share on other sites
jord294 95 Posted April 30, 2016 Plus 1 with Miles I tend to get loads of parts together before taking for powdercoat. If I'm after different colours I take one batch at a time Share this post Link to post Share on other sites
mrfirepro 127 1 Cars Posted May 1, 2016 (edited) on a side issue, how do you find powder coating lasts on underbody parts, I stayed away from it because I believed it would chip too easily, was I right? Reason I ask is that I'm just about to start the next 205 and would like to powder coat due to the superior finish Edited May 1, 2016 by mrfirepro Share this post Link to post Share on other sites
Andy_C 50 Posted May 1, 2016 Paul, I'm sure Miles mentioned this to me a while back. FWIW, I chipped a newly powder coated wheel recently and had to have the whole thing redone as it chipped through to the alloy and it's a custom colour too - paint would have chipped maybe but could have been easily touched in. Share this post Link to post Share on other sites
Juttie205 123 2 Cars Posted May 1, 2016 Will let u know mate as everything under mine is powder coated. Share this post Link to post Share on other sites
welshpug 1,678 Posted May 1, 2016 powdercoat is typically a very hardwearing coating, however thorough and proper prep of the piece is important, especially on aluminium parts where the corrosion and soaked in oils can be very difficult to remove. Share this post Link to post Share on other sites
barneys66 125 1 Cars Posted May 1, 2016 it varies allot, Having 1 item will not help at all, I know my place charge a set up cost so the more done the cheaper it is Plus 1 with Miles I tend to get loads of parts together before taking for powdercoat. If I'm after different colours I take one batch at a time Thanks - I did say to the guy I wasn't in a hurry so they could hold it until they had some other bits to do in black, plus I haven't really got any other bits needing doing (apart from the wishbones maybe) unless I start creating requirements or taking bits off my truck which will need doing at some point. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted May 1, 2016 I tend to use a company that does Blasts and paints Dumpers & Digger's now for allot of suspension parts as the paint they use is very much like the original and hard as, the main issue with Powder coating is that you cannot do bolt/nuts up tight as they generally come loose of the coating cracks due to it being so thick which is covering up a bad surface is fine and thats it really Share this post Link to post Share on other sites
