tyerz 1 Posted April 20, 2016 Does anyone have the pinout data for the 2 round plugs on a V6 loom, started working my way through with a multi metre and found some but it's stuff like the switch live and rev clock I'm struggling to trace, and any data to confirm what I think is right would be much appreciated Share this post Link to post Share on other sites
Goliath 94 Posted April 20, 2016 I'm sure I had them somewhere but cannot find them anywhere. I have an ECU pin out if that is any use. There's a schematic and list of components here (courtesy of M@tt) http://www.buzzboxx.co.uk/406_V6_Wiring_Schematic.jpg http://www.buzzboxx.co.uk/406_V6_Wiring_List_Of_Components.pdf Failing that, try sending a PM to 'Ade_4wd' on here as he might well have a pin out. 1 Share this post Link to post Share on other sites
welshpug 1,678 Posted April 20, 2016 those two plugs will be much the same as any other 406 of the same age. Share this post Link to post Share on other sites
tyerz 1 Posted April 20, 2016 I was talking to ade via pm then he just went quiet? Don't know why sent a couple of messages and had no reply but here's what I THINK I have managed to work put so far. Looking at the plug with the 3 pins at the top working from left to right I have 1. 2. 3. 4. 5.coolant 6.coolant 7.K-lamp 8. 9.diag port 10. 11.speedo 12. 13. 14.oil pressure 15.earth 16. 17.diag port 18.alternator warning lamp 19.starter 20. 21.fuel pump 22.perm live 23. 1 Share this post Link to post Share on other sites
tyerz 1 Posted April 20, 2016 And working from the info ade gave me this is the 306 pinout info for phase 3 hdi 1 - Ground 2 - Alternator warning lamp 3 - Reverse switch 4 - Reverse switch 5 - switched 12V 6 - 7 - Tachometer 8 - Starter motor 9 - "K" lamp 10 - Coolant high temp lamp 11 - Coolant gauge 12 - Oil pressure lamp 13 - Diag connector 14 - Oil level gauge 15 - Oil level gauge 16 - 17 - Diag connector 18 - Fuel pump 19 - Oil temp gauge 20 - Speedo 21 - 22 - 23 - Share this post Link to post Share on other sites
welshpug 1,678 Posted April 20, 2016 http://www.autoelectric.ru/auto/peugeot/406/p8c/p8c-3.gif Share this post Link to post Share on other sites
tyerz 1 Posted April 20, 2016 I'm gonna sound a right simpleton here but I don't understand all the wiring diagrams, the bits I have managed to work out I have done with a multi metre and doing continuity tests from sensors back to the round plug Share this post Link to post Share on other sites
welshpug 1,678 Posted April 20, 2016 (edited) 1c02a and 1c02b are the two 23 pin plugs, pin numbers down the middle, wire numbers each side. mr is maroon so thats 1c02a, gr is grey so 1c02b. 1320 is a 55pin ecu plug, can't remember which ecu that diagram is for, but wire numbers are specific to functions. Edited April 20, 2016 by welshpug Share this post Link to post Share on other sites
GazMav 3 Posted April 21, 2016 Use the attached file to help with the codes on the wires. (It helps if you have a copy of Autodata as you can trace the wires on the diagram) This link helps to work out what the codes on the wires mean: http://www.autoelectric.ru/auto/peugeot/wd/wiringdiagrams.htm These links helped me: http://forum.205gtidrivers.com/index.php?showtopic=88367 http://pscuk.net/threads/71582-205-GTi-brown-multiplg-diagram Only takes about 4 wires to get the V6 running. Main issue I had was getting the two relays to "turn on". It would turn over but not fire, then I managed to get the relays sorted and it fired up first time. Share this post Link to post Share on other sites
