PhilNW 46 Posted February 1, 2016 Been searching for best place to get some of the above oil and some people are now offering Total Gear 8 75/80 as the replacement for the BV version Checked Total's web site and both oils appear to match PSA spec of B71 2330 AND API GL-4+ Anyone had experience of using it? Any reason why you shouldn't? Share this post Link to post Share on other sites
SweetBadger 99 Posted February 1, 2016 I've used it in a BE3 box and it seemed to do the trick - had no issues with it. Share this post Link to post Share on other sites
PhilNW 46 Posted February 5, 2016 Should have explained a bit better that the gearbox has a tranx LSD in it , just wondered if the gear 8 oil is suitable for the LSD Not had any problems with the BV version Share this post Link to post Share on other sites
petert 616 Posted February 6, 2016 Add approx. 40mL of Redline friction modifier. Share this post Link to post Share on other sites
boldy205 75 Posted February 7, 2016 Add approx. 40mL of Redline friction modifier. I guess this reduces the "clunking" and pulling on steering at slow speed, tight turns? Or are there other advantages? Share this post Link to post Share on other sites
petert 616 Posted February 8, 2016 Correct, just add enough until the clunking reduces to an acceptable level. Share this post Link to post Share on other sites
boldy205 75 Posted February 8, 2016 Will give it a go! Cheers! Share this post Link to post Share on other sites
dcc 855 Posted February 8, 2016 I found I used 2 bottles to my gearoil with plate diff. With no modifier it was horrible under 5mph turning Share this post Link to post Share on other sites
dobboy 231 2 Cars Posted February 16, 2016 I've ordered some of the total gear 8, have not long put Titan Syn 5 in..... ???? I've never had a plated diff before but after recently fitting one, and maybe done 50/70 miles or so, i'm beginning to hear the clunking at fairly slow speeds, but i also hear what i can only describe as sounding like a tyre rubbling off a bit of unattached plastic trim.... Or like the sound when you spin a wheel by hand when it's jacked up, from the disc/brake pad. The sound seems to appear randomly and from mid to NS, is this normal? Share this post Link to post Share on other sites
dcc 855 Posted February 16, 2016 The clunking yes, anything else you'v described sounds like you've done a silly and forgotten to do something 1 Share this post Link to post Share on other sites
dobboy 231 2 Cars Posted February 16, 2016 Cheers dcc. Can't think of what else it can be, there is no slack trims etc, and nothing I can think of that can rub..... Lambda cable on a shaft but I doubt it and doubt it would sound like it does. Back up on the axle stands again.................... huh Share this post Link to post Share on other sites
boldy205 75 Posted February 17, 2016 I found I used 2 bottles to my gearoil with plate diff. With no modifier it was horrible under 5mph turning I presume this has no effect on the synchros? 1 Share this post Link to post Share on other sites
SweetBadger 99 Posted February 17, 2016 I don't bother using any additive for my box with a 3J diff as the car rarely sees the road and the chatter/clunking doesn't bother me. It is quite bad with tight low speed turns though - does anyone know if the chatter/clunking is bad for the diff or could cause premature wear on the plates. If it does I'll get some of the additive in there! Share this post Link to post Share on other sites
dcc 855 Posted February 17, 2016 I've not had any problems so far, I dont know what affect it will have on them tbh. As yet no problems (10k+ miles) Share this post Link to post Share on other sites
dobboy 231 2 Cars Posted April 26, 2016 Got to say, my Gbox feels better since removing the Titan Syn stuff and putting Total 8 in, somehow sweeter from cold. I never added any modifier. Share this post Link to post Share on other sites
And 15 1 Cars Posted April 27, 2016 I had issues with the Titan sync stuff to I got it as as I won £50 to spend with 710, it affected my sincros badly but I believe but could be wrong that it's really for dog engagement, I just run total BV now no adative as its a stage car the clicking don't bother me but saying that the Titan was just as loud.. Share this post Link to post Share on other sites
Rippthrough 98 Posted April 27, 2016 They had a lot of syncro issues with RX-8 boxes with Titan in too. Opie had them investigating but it I don't think it ever came to anything. Share this post Link to post Share on other sites
