idoari 10 Posted July 28, 2015 (edited) Hi, i just went to the dealership here in Israel and got a pair of shocks but the part number is different. they say that Peugeot replaced the part number again from 5206 TE to 98 114 026 80 . But i can't seem to find this part number in "peugeot service box" website. can you call your dealership and find out if they truely changed it? and if not, if i got the correct part? what car is this part fits to? thanks Ido aricha Here's what i've got? ​ Edited July 28, 2015 by idoari Share this post Link to post Share on other sites
Slo 283 1 Cars Posted July 28, 2015 Looking it up it seems that 5206 TE is the superseeding part number for 5206 K6 as you are already aware, I think they might have fobbed you off because they had it in stock and it will at least fit your car. It doesnt look right to me it seems a bit thin but looks dont mean anything anymore. Share this post Link to post Share on other sites
idoari 10 Posted July 29, 2015 can anyone check the diameter of the shock tube on the original 5206 K6? mine is 46mm in the fat part and slightly over 40mm in the narrow side. the length of the fat parts is 94mm and about 170mm from the top of the shock to the fat part. Share this post Link to post Share on other sites
Alan77 78 1 Cars Posted July 29, 2015 Sorry, can't help with the dimensions you ask for, but here's a pic of 5206TE for reference, which I put on my car a couple of years ago. Share this post Link to post Share on other sites
S@m 156 Posted July 29, 2015 I can confirm that that is a correct part number change, it can be seen on parts letter LE-2014, but i suspect only dealers will have access to that. Here is a small excerpt showing the Peugeot part change; http://i.imgur.com/3DxX4M1.jpg I should note that when a part number is changed in this way it doesn't necessarily mean it is a direct replacement, only that it will work/fit. The damping properties may be different to 5206TE. Share this post Link to post Share on other sites
farmer 328 1 Cars Posted July 29, 2015 Sam Any Citroën dealers got the old numbers I forgot to check ? Share this post Link to post Share on other sites
Slo 283 1 Cars Posted July 29, 2015 I should note that when a part number is changed in this way it doesn't necessarily mean it is a direct replacement, only that it will work/fit. The damping properties may be different to 5206TE. Spot on. Thats what I meant when I said it will at least fit. Share this post Link to post Share on other sites
welshpug 1,722 Posted July 29, 2015 (edited) Citroen show 5206 TE for the zx Volcane and many Xsara's, the 16v (J4 and J4RS) used 5206 N0. No superseding notes that I can see for the 5206 TE from citroen. Edited July 29, 2015 by welshpug Share this post Link to post Share on other sites
idoari 10 Posted July 30, 2015 The million dollars question is : is the new dumper will be the same as the old one in term of dumping? Share this post Link to post Share on other sites
welshpug 1,722 Posted July 30, 2015 quite unlikely, I would send them back if at all possible. there was a similar difference with the bilstein b4 dampers a few years ago, now rectified thankfully. Share this post Link to post Share on other sites
erbs 42 1 Cars Posted January 28, 2016 So would we need to go to Citroen for the dampers 5206TE? Share this post Link to post Share on other sites
m@ttc 30 Posted January 30, 2016 Why go to Citroen and not Peugeot? Share this post Link to post Share on other sites
welshpug 1,722 Posted January 30, 2016 they may have stock where Peugeot don't Share this post Link to post Share on other sites
m@ttc 30 Posted January 30, 2016 Ok, it doesn't show nfp on service box, and I plan to buy some myself next week that's all. Share this post Link to post Share on other sites
erbs 42 1 Cars Posted January 31, 2016 Ok, it doesn't show nfp on service box, and I plan to buy some myself next week that's all. are you going to peugeot or citroen for the dampers, let me know how much they are each when you do please Share this post Link to post Share on other sites
m@ttc 30 Posted January 31, 2016 I plan on going to Peugeot 5206 TE £71.78 each. Share this post Link to post Share on other sites
erbs 42 1 Cars Posted January 31, 2016 (edited) they got to be better than the bilsteins, don't think you can beat oe parts, worth every penny. thats where i'm off next week, to start collecting bits for my beam rebuild can you still get the rubber mounts from peugeot still?? the squared sandwiched ones Edited January 31, 2016 by erbs Share this post Link to post Share on other sites
Alan77 78 1 Cars Posted January 31, 2016 they got to be better than the bilsteins, don't think you can beat oe parts, worth every penny. thats where i'm off next week, to start collecting bits for my beam rebuild can you still get the rubber mounts from peugeot still?? the squared sandwiched ones Enjoy getting beam parts without buying bags of multiples. Febi sandwich mounts are only £6 each. Share this post Link to post Share on other sites
erbs 42 1 Cars Posted January 31, 2016 i spoke to a member on here who is going to do the rebuild for me, i just give hime my beam,it might come back with the sandwich mounts, if not will get the from peugeot,was seeing if they still do them Share this post Link to post Share on other sites
erbs 42 1 Cars Posted January 31, 2016 are the febi sandwich mounts any good?? Share this post Link to post Share on other sites
m@ttc 30 Posted January 31, 2016 http://m.ebay.co.uk/itm/FEBI-21819-Mounting-axle-beam-Rear-Axle-left-or-right-/301817260658?txnId=1217215479020 I brought the febi ones off eBay last week, also got febi sandwich ones off the same seller Share this post Link to post Share on other sites
Alan77 78 1 Cars Posted January 31, 2016 i spoke to a member on here who is going to do the rebuild for me, i just give hime my beam,it might come back with the sandwich mounts, if not will get the from peugeot,was seeing if they still do them Peugeot sandwich mounts still available, p/n 515110, £26.47 each. Are they 4 times better than a febi one? probably not imo. Share this post Link to post Share on other sites
m@ttc 30 Posted February 1, 2016 Just had these come today under £19 for the four bushes, I thought I'd share them. Share this post Link to post Share on other sites
Anthony 1,003 Posted February 1, 2016 Four? Should be six in total to do a complete beam... four of the smaller round bushes and two larger sandwich mounts Share this post Link to post Share on other sites
m@ttc 30 Posted February 2, 2016 Well spotted Anthony, I need to go and buy another 2 small round ones don't I. Share this post Link to post Share on other sites
