Uberderv 6 Posted July 10, 2015 Hi all, does anyone have a link to a fuel pump strip down please? I think the mechanical end is jammed so would like to try and see if I can fix it. Cheers :-) Share this post Link to post Share on other sites
Uberderv 6 Posted July 11, 2015 Sorted it now, I removed the motor/pump from the housing, straightened the upper aluminium tabs on the pump body and pressed the innards out from the bottom. With the case off the innards came apart fairly easy to reveal the mechanical end. Its a centrifugal type pump with tight tolerances, gave it a clean, a dressing another clean then rebuilt it. Works a treat now :-) Share this post Link to post Share on other sites
