laser green 1.9
No Fuel From The Injectors.
laser green 1.9
It is a while since I've been on here but my 205 died on me on the way home last night.
I was drive home when it started to stall and then cut back in. I had to restart it a couple of times but it did restart.
Got it hope and check all the usual stuff. When back out and drove for about 1/2 a mile and then died completely.
So I've spent the day trying to fix it.
It turns over and I have a spark but I cannot smell any fuel.
I've checked and cleaned the engine earth terminal,
checked the continuity on the fly lead coming from the dizzy,
Tried on old superchipped ecu that I have in the garage,
I have fuel pressure at the rail the pump primes and continues to run
Tried an old tachemetric relay,
But nothing has worked.
So my question is how do I trick the injectors into firing or what do I check next. My car is a standard 1.9 gti from 1991.
Thanks, Mike.
opticaltrigger
Hi Mike,
Have you tried a test light in the end of an injector plug to see if it flashes when you crank ?
The injectors are supplied with a common live and they are switched on the negative from memory
O.T.
Edited by opticaltrigger
laser green 1.9
I don't have a test light. I used a spark plug to test for a spark.
I may have to invest in one.
Cheers,
Mike.
ALEX
Id say the tach relay. Or the wiring to it.
