axnutty
Imaxles
axnutty
Looking at imaxles.... howdo they do it for the money? A refurb axle is 250 and a new one just 300! peugeot seals bearings and shafts are £200 , so do we take it they use cheap inferior components? Has any one got any experience with them? Like longterm reports of whether they hold up in the long run? I just believe you get what you pay for and they seem very cheap!
stef205
i have a customer that has had 4 axles from them, all had collaped, my inspection found lack of grease and loose torsion bar nuts, seals appeared to be hard and not doing there job. From what i saw they appear to be mass produced with what seems little care.
Only seen one which used wrong Bolts and washers, Otherwise appeared OK. But as said when you work out Parts, Stripping, Painting, Bearings, Seals etc then at that price I would be making them for nothing and some, I cannot see how they can do a new one with AFAIK Peugeot supplying the tubes still at fair money
I lowered a 106 GTI beam for kezzer recently that came from them, as said, apart from using hex head bolts everywhere that I expected to see torx, it appeared ok but it was the first 106 beam I'd touched so don't have much to go on for reference.
Torsion bars & arb were correct size for the model & the bearings were greased, although not excessively iirc but can't comment on seals being hard as I've not seen a new one to compare.
g
axnutty
Well my Partner van has developed some play and it looks like I do the repair myself with Peugeot bits or I'll give these guys a try then. Unless one of the beam builders on the forum wants to have the job?!
DanteICE
I was going to use them to get my beam fitted with oilite (possible spelling) bearings. Is there anywhere else people know of who can do this work?
Geoff
As above, for the money not a chance, To give you a idea basically new parts come to around £200.00 alone + Labour then blasting and painting, Bush's, Wheel bearings etc and your up around £750.00 again with good quality parts.
Don't bother with anything other than OE spec bearings either for referance
farmer
New beam tubes are now NFP from Peugeot.
Also the bushes are gone.
Only person I know who has the NFP parts is Andy.
I would be sending my beam to him to make sure I got the quality parts.
You can see 309 Tubes being bought up then or coming back to being popular,
farmer
Was only about 6 309 tubes available to order on a dummy order of 100.
Whether that works correctly who knows
