James Cornell
Oil Pump Worry
James Cornell
Just a quick one, I am doing a complete rebuild on my 8v 1.9 and I have put the crank in and when I look at where the oil pump bolts to the bottom of the engine it looks like there should be a locating dowel for the hole which pumps the oil to the head. Is there a dowel or am I just being paranoid?
Edited by James Cornell
No dowel, but the bolt closest to the oil feed into the block has a shoulder.
James Cornell
Cheers petert!
I'm normally quite methodical when I take an engine apart and it is unlikely that I would have lost a dowel, it just looked like there should be one and I stripped the engine down in September.
Yay on with the build ????
