ATK
Any Guides For Replacing Fuel Pressure Regulator?
ATK
Any guides or tips for replacing the standard FPR? Worried about fuel going everywhere so thought id ask! Cheers
dcc
if you're not confident and fancy a run down porthcawl, I'll be there this saturday and can show you / do it with you
fire it up, pull the fuse.
remove pipes from fpr, undo two bolts.
lube new o-ring, reverse removal, turn key to prime pump a few times, should start fine.
check and adjust co level as appropriate
ATK
Cheers Dan, but I'm not around this weekend, appreciate the offer though mate.
I'm assuming pulling the fuse is to allow any fuel to purge from the lines to stop it from spewing everywhere and as long as I do that it should be straightforward?
ATK
Is the correct one Bosch 0280160258?
ATK
Replaced my FPR yesterday, all went well :)
jord294
is this the number you used?
cheers
Edited by jord294
jord294
thanks
