idoari
Which Rotor Arm I Need ?
idoari
Hi,
i have ducellier distributor on my 1.6 GTI (1992) and i want to renewal my rotor arm.
the rotor arm which is install now looks like this
$_57.JPG​
but i saw that the type that should be install looks like that
$_57.JPG​
which one is the correct one ?
my ducellier distributor part number is 2525683A (not a mistake in the number)
my vin is VF320CB6224949982
thanks
Idoaricha
Edited by idoari
idoari
anyone....??
here's my distributor number
IMG_0959_Copy.jpg​
jord294
Having had a look for you, your distributor is listed pre '91.
Genuine Peugeot rotor arm was 5937.28 but now is LE-9202
Hope this helps
DamirGTI
For that type of dizzy you'll need this one :
  On 11/19/2014 at 1:06 AM, idoari said:
The other arm on the picture is for old pushrod Peugeot-Talbot engines where the dizzy bolts into the block rather than the head .
D
idoari
D
OK thanks guys the problem is that i bought the dizzy cap of the other type and it's doesn't fit like the one i have now :(
the one i've bought is the one that include in the kit of peugeot 5940.35
which cap i need?
Edited by idoari
DamirGTI
Dizzy detail :
http://www.miamistu.co.uk/pug/GB/309F/5/59B55A.HTM
OE cap - 5941 41
This is how it looks like :
http://www.facet.it/db_comp/catalogo/product.asp?cod=2.7667PHT
Rotor arm :
OE arm : 5937 28
Aftermarket part (Facet) :
http://www.facet.it/db_comp/catalogo/product.asp?cod=3.7694
D
Edited by DamirGTI
idoari
  On 11/23/2014 at 4:30 PM, DamirGTI said:
Dizzy detail :
OE cap - 5941 41
Rotor arm :
OE arm : 5937 28
D
thanks but it's very weird since my original cap that install on the ditributor is a male type and this is a female type... very weird
do you know that part number for the HT leads ( because it's female type) ?
idoari
is the page that you gave it writen that it's from peugeot 309. am i right?
DamirGTI
This one : http://www.miamistu.co.uk/pug/GB/309F/5/59B55A.HTM .. yes it's from 309 catalogue . I tried searching trough 205 distributors but couldn't find that one from your picture so i guess that someone fitted 309 dizzy instead 205 one ?! or could be different cos it's export car ..
Will take look for leads .
D
