4ll5op
Disconnected Wires
4ll5op
After doing some rewiring I found these were disconnected not sure if I've pulled them out or they have never been connected car seems to be running as normal though
Stuart
Weser
I am not 100% sure but I think pic 2 might be the dash light dimmer switch connector?
I believe you are correct Weser, but the picture is a bit small and I get a large popup when I click on it so can;t actually see the full image! :unsure:
4ll5op
Yes your right it is the dimmer can you not see the first pic its a green and red wire I'll try uplad again
4ll5op
I think those may be the sidelight wires.
4ll5op
All my lights are working though as I rewired them when I connect the green wire to 12v I can hear clicking maybe the injectors? But the car is fine without these connected someone has rewired everything for the brown multiplug directly to the dash could they just be left over from that?
