sale_gti6
Xu10J4Rs Hydraulic Lifters
sale_gti6
I need advice. Several hydraulic lifters knocks on my Gti 6 engine and I'm plan to replace them. Also, I have hydraulic lifters from my previous Xu10j4 S16 engine,and I was wondering if S16 hydraulic lifters fits on Gti 6??? If they fits, I do not have to buy new lifters...
Yes, identical bore but slightly different length. I would use the S16 lifters (reco'd) if I had no RS lifters.
sure its not the valves?
sale_gti6
I thought so, but I was not sure. thank you
sale_gti6
I check timing and it's OK. When engine is cold, nothing knocks. Suspect hidraulic lifter...
calvinhorse
Any idea if the j4r and j4rs lifters are the same or if the J4 lifters will fit a J4r?
calvinhorse
Also are the xu7 lifters/followers/buckets the same?
ive looked at some eBay listings and it shows pretty much all XU 16v buckets and lifters are the same?
they're all the same o.d, I think there are differing part numbers but they look to be identical, Peter said they would fit above.
its the EW engines that went smaller o.d to make the valve train lighter.
infact I have all 3 types, maybe I should take them all apart :lol:
Please do and report back. R and RS lifters are definitely different part numbers but I can't see how the relationship between valve tip and base circle diameter is any different.
calvinhorse
Yes please have a look :D
my predicament is I have a j4r head with no lifters but I have a xu7 head on the way and about a million j4 heads
XU7 and R: 0942 45
RS: 0942 31
calvinhorse
Is that the internal hydraulic part?
Nope. The whole thing.
Edited by petert
calvinhorse
Ahhh brilliant, thank you
