MiniGibbo
How To Remove..?
MiniGibbo
Clutch cable (ma box)
Speedo cable
gear linkages
Advice please :D
S@m
My advice? Buy a Haynes manual. :P
  • Like 5
Lowercase
pop gear linkages off with spanner.
clutch cable, pull the arm on the gear box back and slide the cable out the side.
speedo cable... engine crane.
Or download it & have a read?
g
TooMany2cvs
Disconnecting the speedo cable's straightforward from the box - there's a rubber "pip" going in to the side of the casing, just at the bottom of the cable. Give that a pull, it'll pop out. Then just lift the cable out the casing.
To refit, just push the pip back in, until you can give the other end a bit of a pull, and it pops home.
(Or, at least, that's how it was on ours a few months back, IIRC, but I've been to sleep since then...)
MiniGibbo
Have a Haynes manual and all it seems to be good for is resting my drink on..
Thanks guys..!
