chipstick
Coilovers With Standard Top Mounts
chipstick
Thought I'd do a quick coilover assembly earlier so I could see how they went together.
Here on the right is the top mount assembly minis the original 205 spring seat and bearing.
AE045D51-E1D7-48C3-9576-7C10CEE0D056-179
Assembled like such
199AAF47-5EA1-423F-BC4E-895780F699C8-179
Here's the spring with the Gaz seat.
6C8A3A4C-7981-4638-9F10-0ABFF6F2C708-179
Does my mock assembly a few pics above fit on top of the black Gaz seat without any bearing?
I wondered if an original bearing would fit in mix, but couldn't see how it would effectively without movement.
So in my mind this is how it would go - although I'm not convicted so seeking some clarity
Upside down with spring rising from this:
770065BB-F695-4E9E-952E-6BEA19E94E2D-179
AF84C283-82EA-4D4F-AF69-4F5D16A0CDA2-179
Do many people run these without helper springs? Mine are 8" springs and won't be far from coil bound on the lowest setting by the looks of it
68B334D1-44B5-4C2A-AE62-5E13AF4C4A38-179
You need some bearings, if helpers are coilbound with no weight on the car you dont need them.
chipstick
I think I've sussed it now.
BB5A458A-B3C0-47D9-B6A1-FB09029B2668-179
Obviously that's not fully at home - it's corroded and there's no point me forcing a used one on.
Allows it to then sit like this:
56136F8B-D131-432D-B07E-8181601D85C0-179
3D9CDD83-9C4A-4262-832E-FC14BE567D7F-179
That's got to be how it goes :)
calvinhorse
That's how mine are, not sure if it's 100% correct as the bearing seams a bit open to the elements.
chipstick
Now ready to bung these on the car but have a final question about the thick washer.
On one set of shocks I split down the washer was in this position to space the cup:
8EDC270F-231B-4429-B62D-28FB5E9D6DD0-200
On another it was directly on the shaft which I would say was correct but want to be sure:
2544BE89-C4F1-4D44-BC86-AFFF43E3C0A9-200
Service box diagram doesnt show the position of it annoyingly!
yep, should be on the top of the shaft under everything,
you'll notice the original bumpstop has a matching recess in the top.
Edited by welshpug
chipstick
Brilliant. Thanks Mei :)
