Alan_M
Beam Tube Lengths
Alan_M
Right, I've delved through the search results and can't find any info.
I'm after the actual beam lengths on a 205 and a 309. All I've found they're 18mm different each side.
Am I also right in thinking the ZX ABS arms add another 9mm each side?
stef205
yes 9mm, they will aslo give you neg camber.
chipstick
I've got both laid up in the shed so can measure them if you've no luck with lengths of each.
Alan_M
Yes, please!
Its the hubs not the arms that make the difference to the track.
The 309 torsion bar is 37mm longer than a 205 one so I'd expect that will also be the difference in beam tube width.
g
chipstick
309 tube length is ~972mm
The 205 one I have has an arm left on it so won't be able to get an accuracy guesstimate on that.
Alan_M
Thanks. 205 tube should be in the 935mm area then if there is 37mm difference.
Just meaured a base model beam tube & it is.
g
