ORB
Battery Terminals
ORB
What are your opinions of this type?
FF6BC843-297A-475B-9694-8F5413414881-255
As they are the standard ones I have for my XU10 engine, I was thinking of retaining them, but I don't have the battery side of them. (Anyone got some going begging?)
Ta
I still have the standard GTI ones, just thought these look neater?
MEH. <_<
that is my opinion.
much rather a standard clamp tbh.
ORB
I figured so!
I thought the same, but was trying to convince myself to the contrary....
AlexRS2782
I fitted a set of the ones Welshpug has pictured on mine when i first got the car and they've been fine :)
Much better than, what i think were, the Saxo screw on fixings the previous owner of mine had fitted (badly).
pugpete1108
I've managed to snap a couple if the ones wp has pictured
also found the screws a bit w@nk so put the wires in and filled the rest with solder..
Ditched them when the cast snapped and used the std xu7 I had which I desoldered and resoldered along with a different style negative clamp from my local motor factor
cheesegrater
How did you snap them? Its only a pinch bolt barely needs to be done up at all.
Daviewonder
I'd go with the red and green screw on ones all day long.
Daviewonder
MEH. <_<
that is my opinion.
The screws that hold the cable in reek of a bodge to me.
omega
with the screw type you have to be carefull because they are not all the same size screw thread!
i found this out when the battery on my 406 died and i scrapped the battery with the screw thread on it,went to the scrap yard to get a replacement came home to fit it and it was to small.
but once fitted never had a proplem.
the screw thingy is NFP for the positive terminal.
neg terminal thingy is not, but is different size.
pugpete1108
i think the amount of time i actually removed the battery to charge the bloody thing up :lol: weakend it over time.
damien
hate them red screw ones, i replaced mine with the same as WP ones
harryskid
MEH. <_<
that is my opinion.
Proper job! :)
Shakey_Jake
I replaced mine with the one welshpug pictured for my battery re-location.
