BlueBolt
Wishbone Balljoint Replacement
BlueBolt
Following on from this thread::
http://forum.205gtidrivers.com/index.php?showtopic=147748&do=findComment&comment=1329938
I thought i would start a fresh thread to discuss the possible ways in which to do so as I thought it would be diverting from he OP's reading an such...
Tom, would it be possible to drill it out, heat it out, smash-10-barrels-of-sh*t it out?? And heavy press a new one in??
I know that the bones are now reasonably cheap, unless you want something better quality which will last, but surely there has to be a way to do it??
1. Even if you can get it out, where are you going to buy a new one?
2. At the price you can buy them for, if paying someone else to press new bits in and out would it really be economical to do anyway?
I wouldnt call £75+ for a decent wishbone cheap, when a 306 wishbone can be had minus BJ for under £20, and a BJ for £6.
I have pressed a BJ out, it was very easy and didnt take many tons at all.
however the issue is finding something that will go back in, the body of most BJ's I have seen are much bulkier (106 for example) though I havent measured up, there is a contact of a Forum member that can sort a Spherical Joint much like the satchell wishbones, far stronger and significantly cheaper than a RJ welded on.
stef205
I've rang first line technical they list a joint for the arms, but as said its getting it out.
DamirGTI
Over here , some machine shops offer servicing/press-replacing the balljoints .. as well as few firms which are specialized in manufacturing balljoints , droplinks , U joints etc.
So yes it can be done .
(not so sure but i think that they press in a Renault 19 16v balljoint into the 205 wishbone , as it's the same size ..)
Damir B)
Edited by DamirGTI
omri617
I will try it and let I know
Edited by omri617
hmm, I doubt its that one
parts-Ball-Joint-renault-19-i-b-c53-1-8-
got a part number? Its not in the catalogue which was updated 26th Jan 13.
omri617
So for now , even if we pull the ballpoint out , no current replacement .
DamirGTI
Meant the R 19 16v balljoint when it's not pressed in the housing for use on actual vehicle .. the ball itself , apparently same fitment when pressing in the 205 wishbone .
Damir B)
Take look @ this :
http://projects.205gtidrivers.com/205mi32-ph7?page=9
Edited by DamirGTI
stef205
No you need to measure it and ring them they will give you one that fits
Edited by stef205
omri617
The person who locates the correct balljoint for the 205 GTi triangle , I'd buy him a beer
Rippthrough
Someone drops me an old arm off I'm sure I'll find something...
what's your address Phill? :)
that's not really the bit that wears :( its the plastic cup it resides in that wears.
omri617
This fits into the wishbone ??? got a link for actual item ?
Funnily enough I saw details of someone doing a pair of 944 wishbones on the retro rides forum earlier, however at that price its nigh on cheaper to replace the complete wishbone given they also come with bushes pre-fitted <_<
IMAGE_9B86E486-0053-408A-A720%20-D352672
IMAGE_DB6BA52F-408B-4C40-B9F5%20-29CD987
IMAGE_7DBBCE9B-0E75-434D-B044%20-9F25118
kostas205
After all these years, has anyone found a way to replace the wishbone ball joint?
For the comparatively low price of new ones, it’s not remotely viable.
kostas205
I am struggling to find new ones with the correct casting. I ordered Delphi ones from Autodoc this month and they were wrong.
Tom, are you aware of any brand that has the correct casting? I am in Europe.
bacardincoke
Discussed on this thread... https://www.205gtidrivers.com/forums/topic/176200-decent-wishbone-suppliers/
... @Jord294, who at the time of writing, makes the last post mentions he's yet to try Febi and SKF's offerings.
I can unfortunately confirm SKF's (left and right)  VKDS 323076 B /  VKDS 323077 B are of the type that don't fit (with the Chinese emblem on).
SRDT
There is no room to replace the whole joint, you could replace the guts with those from a 106/AX ball joint but once opened you can't re-roll the lip to close it again.
  • Thanks 1
