aarontrophy
Daily Driver
aarontrophy
205 gti 1.6 or 205 Rallye / Xs
To use every day what you guys think ?
johnnyboy666
xs, fuel economy and fun. usually pretty reliable. used to get about 42mpg from a tu3s with a heavy foot.
Weser
Not forgetting the cheaper tax.
Depends to a point what your everyday drive consists of.
If it's mostly twisty B-roads, then a 205 XS - fantastic cars that are massively under-rated.
If it's mostly motorway, then a 205 GTi, although preferably the 1.9 (the torquier engine and longer gearing are far better suited)
If it's a mix of both, then I'd give the nod to a 205 1.6 GTi all things being equal as it's a fractionally better all-rounder.
Really though, it's whatever the best example you can get for your money - I'd much rather a good GTi than a rough XS, and vice-versa.
I wouldn't personally even consider the UK Rallye - other than arguably looks, it has absolutely nothing over an XS and typically costs far more thanks to the badge. If you really want a "Rallye", I'd just buy a white XS, sticker it up and put it on 106 S1 Rallye steelies - then you'd have something that was fun and looked the part.
AlexRS2782
Being a small engine, the XS comes under the £135 p/a ved bracket doesn't it? Nearly £100 saved there vs the GTI.
Lowercase
the manual choke and carb set up of an xs could get on your nerves though. if not set up properly then your going to be late for work a lot.
mine drove me mental so i switched to injection.
good fuel economy though.
