starky5
Thermostat Info
starky5
Hi I'm about to swap my 1.9 8v for an mi16, can I use my current thermostat on the mi? Thanks
You can use the 8v one, but two points of note:
1) The rear coolant bypass rail won't work properly without an Mi16 thermostat
2) New thermostats are cheap enough (particular for a generic non-Mi16 one) that I would just replace with a new one as a matter of course
Also, use new seals as a matter of course - often come with new 'stats, otherwise cheap to buy separately.
cybernck
This one has always puzzled me - is it really required?
One of my Mi16 engines' coolant system didn't seem to function correctly with it removed/blocked.
starky5
Ok I'll pick one up, what was the model of 405 with the mi16 called? Will make life a lot easier when I head to my local motor factor!
S@m
It was called.......the mi16.
Lmfao!!
1338 03 is the part number BTW, early cars used two seals, one either side, later ones used a seal that wraps around the thermostat.
Edited by welshpug
starky5
Is this the correct thermostat for the mi16? http://www.carparts4less.co.uk/cp4l/c/Citroen_BX_1.9_1990/p/car-parts/car-cooling-parts-and-car-heating/cooling/car-thermostat/?209545021&1&130192e37329de359fe61525f6583ca0aa7ffa56&000325
Service box is listing 1338 03 as NFP and my local motor factors seem to be rather unhelpful when i talk to them without knowing the cars reg!
That's a standard 8v thermostat.
The Mi16 thermostats have a 2nd part on the back that interupts flow to the coolant bypass rail across the back of the head.
I'm pretty sure that it's this thermostat that you need.
starky5
Ideal thanks for your help, ill get one on order and cross my fingers its the right one!
