hua5329
205 Xr Replace The Saxo Vtr Engine.
hua5329
Hi!Everybody
I am a 205 XR owner from Taiwan.
My engine is TU3S with a Solex 34/34 z1 carburetor and 205 XS manifold.
And I want to replace a 1996 year SAXO VTR engine (1.6 8v).
But I have some questions as follow:
1.Can the AX GT manifold fit the VTR engine cylinder head?
2.Would the TU3S distributor fit on the VTR engine camshaft?
Because I can't find the VTR engine wiring loom harness.
I must continue using the carburetor system.
Please give some suggestions.
Many many thanks!
calvinhorse
Simple answer is no too both questions..
The inlet manifold bolt pattern is wrong.
The vtr cam doesn't have the lobe for the mechanical fuel pump, and the ignition map is not perfectly suitable for the 1600 engine
You can use your xr thermostat housing and dizzy mount on the vtr head
Edited by calvinhorse
calvinhorse
P.s car looks nice, more photos please!
should be very easy to find a VTR ecu+wiring loom on one of the UK saxo forums tbh.
hua5329
Thanks for your suggestions.
I will check these details and take more photos.
Thank you very much!
hua5329
thanks for your suggestion.
But the saxo VTR parts are not easy to find in Taiwan...
I think that continue using the carburetor system is a easier way to me.
did you not read my post?
calvinhorse
One option is to put your cylinder head on the vtr block
hua5329
The option sounds really good.
I will try it!
Many thanks!
Yes!I read it
But some people doesn't want send these itemes to foreign countries.
If these itemes condition were bad.
It would be a trouble to me.
I really appreciate your suggestion.
Thank you!
