bearmach
Dashboard Cleaner
bearmach
Anyone know of a good dash restorer, Mine has fadded an needs some attention
MiniGibbo
Autosmart G101 to clean mixed to 10-1
Chemical guys natural look to seal.
SurGie
Platicare will give its colour back grey or black, it a dye. It says 20 min dry time but for me at 20 degrees can be more. Its made my rubber and plastic parts look brand new.
You can get it from here and ebay, even has a 205 on the front cover, mine doesnt currently after using it quite a bit.
MiniGibbo
why would you plasticare a dash..? you can clean them back to an oem finish without the hassle..
GLPoomobile
I expect you'd only use Plasticare if you wanted to change the colour, or if you needed to restore the colour due something like....oh, I dunno.....fading?
I wouldn't dive straight in to dying it though. See what you can achieve with cleaning and some more temporary dash/plastic treatments first. The problem with using something like Plasticare is that unless you can get a perfect colour match, you really would need to do all the dash plastics so they match up, which then becomes a problem when you get to the heater control panel :(
Edited by GLPoomobile
MiniGibbo
Ive not personally come across a car with a dash faded that badly.. bit of the above i said in my first reply brings my dash up like new in the 205.
GLPoomobile
True. They must have some viscious sunshine in Caerphilly though :D
MiniGibbo
Best remember to put my sun reflector in the screen next time im passing through...
Andy_C
Einszett Cockpit Premium best cleaner/protector I've used and leaves a nice matt finish too. Clean with an old toothbrush and any soap/shampoo first to make sure squeaky clean and off you go :)
SurGie
This is how mine looked after the windscreen section was done.
johnnyboy666
that picture looks like when you accidentally take a photo on your phone when its in your pocket
eastlondonpug
I had used Armor All protectant spray around 13 years ago on my dads and friends cars in KSA. That is what everyone used over there and did a pretty decent job of cleaning, protecting and mildly polishing (as long as you don't use too much). Considering that we used it on dashboards in 40-50 degree celsius heat it did a pretty decent job.
Amazingly, I found it here in the UK too at around £5 or so. I has used it on all my doors and plastics etc to clean/maintain and seems absolutely fine.
