luchjeg6 0 Posted September 3, 2012 Why on a french car are they in inches size??? Share this post Link to post Share on other sites
Tom Fenton 1,650 Posted September 3, 2012 They are not, they are all metric sizes. Where have you found imperial (inches) sizes? Share this post Link to post Share on other sites
Baz 421 Posted September 3, 2012 They won't be original if you have! Share this post Link to post Share on other sites
wicked 107 3 Cars Posted September 3, 2012 Note that M7 is used on some parts; it's metric, but not available at all shops. Share this post Link to post Share on other sites
welshpug 1,737 Posted September 3, 2012 Are the seat belt bolts not an imperial thread but 17mm head?... But otherwise certainly all metric, with many 16 and 18mm heads on the nuts and bolts, as well as 17mm! Share this post Link to post Share on other sites
luchjeg6 0 Posted September 3, 2012 And the oil pan bolts? And in some other bolts 10 is too small and 11 is ok but with a lot of play, Share this post Link to post Share on other sites
welshpug 1,737 Posted September 3, 2012 maybe you have a worn socket? those are M7 indeed. Share this post Link to post Share on other sites
EdCherry 34 1 Cars Posted September 3, 2012 M7 and 1/2 UNC are used if I remember correctly, as pointed out the seatbelt bolts are imperial unc but with a metric head. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted September 3, 2012 And the oil pan bolts? And in some other bolts 10 is too small and 11 is ok but with a lot of play, An 11mm socket should fit them perfectly & a 6mm allen key for where these are fitted. Most M7 hex bolts have an 11mm head. g Share this post Link to post Share on other sites
