zowow
Bad Idle
zowow
Hi..
i've just bought quite a mint 2.0 405 Mi16 and it has a really bad idle and keeps cutting out. Does anyone have a photo of where the idle speed control valve is located?
Cheers.
stuart.m
click
Not a brilliant pic (you can hardly see it there, obscured by the diaphragm) but you get the idea, its a cylindrical thing, with the connector on the top and the air hoses on the bottom, it sits in a rubber mount sort of thing thats attached to the engine lifting eye. I'd also check the vacuum pipes that goto the map sensor (in the ecu) - if its getting a wrong map reading it can behave pretty weird.
Edited by stuartm
Guest jontg428
  stuartm said:
click
I had a similar issue, turned out to be the throttle position switch. Clean the idle air motor and go for a drive, or swap it out as its a common bosch part. My car would either idle too high or too low, once I replaced the switch, issue resolved.
