Sloppy
K Light
Sloppy
the engine K light is always on when i start the car for a few secs? is this normal or not? and common places or faults to check
Used to have check engine light too but this went after new coil packs and gti inlet :D
JamesLeMans831345402285
Umm thought the engine warninge and k light was the same :rolleyes: doh well,
Anywho no lights stay on mine after ignition is on, so I guess not normal, I reckon its detecting acav as faulty because you removed it?
Sloppy
good thinking could be but it used to be there before, but then again the avac was not wqorking spot on???
yes its normal, it should go off after a few seconds.
Bonez
as said normal :)
as long as it goes off after a couple of seconds
  Bonez said:
as said normal :)
I disagree, at least on phase 2, my k-light stayed on for a few secs after ignition when i had a faulty acav solenoid. After replacing it, it went away. Returned when one of my diaphragms died replaced that and away again. Currently no lights on my dash whatsoever after spark.
Sloppy
so what you saying yours come on with the ignition but then straight off as soon as it fires?
Yip
Guess the best thing to do for a definitive answer is make yerself up a fault code reader, theres a guide on here somewhere..
Edited by JamesLeMans83
Guest badboyracer3500
Mine does the same, goes straight out after firing.
Feeble
Same here... Hope it's nothing worth worrying about...
stuart.m
mine always stays on for a second or 2 after starting the car, even when theres no faults logged in the ecu, assumed this was normal
*shrugs*, well when my acav problems where about the lifters were not moving, that was when I had the light for a few secs on ignition, got the acav working again and the light goings out straight away on spark. So im guna go ahead and say it was definately recording a fault - even though i never got a reader made...
It does return to that state now and then, every few thousand miles (when the acav working fine tho) tends to occur if its been running rough ie some what i assume is pinking. Don't know what the cause is but a quick battery pull clears the light on ignition and she runs smooth again. not had the k-light come on whilst running yet.
Isn't there an urban myth that you will probably see the k light when starting after a stall because the engines flooded?
