Bluegalaxy1056
Erasing Fault Codes On Mi16
Bluegalaxy1056
Hi there,
Does anyone know how to erase the fault codes on 1991 mi16 1.9. I have got fault code 44 (knock sensor) coming up. Have serviced the car, fixed a vacum leak, dissy cap, set the air/fuel ratio correctly and also chaged knock sensor but need to erase the code to see if it has fixed the problem.
Anyone got any ideas
KRISKARRERA
Disconnecting battery is one way. The proper way I can't remember.
Welcome to the forum :D Could you fill in your location on your profile please.
cybernck
well you could say that it is the correct way.
it's not like the codes won't come back if errors are still present :).
Bluegalaxy1056
Ah cheers.... Yeah i have tried that one and the light still comes back.
Has anyone come across this problem before?? If so anything else i could check before i start attacking the wiring <_<
lee-bg
Set "Ground" for the pin2 of diagnostic connector for 15 seconds
that erases error. but they will come back if its permanent error which occurs again
you can check it and see what error it gives. its easy.
KRISKARRERA
Hehe I'm following you around the net! JUst read this on the BX forum too. ;)
