Karl
Gti6 Flywheel Mashed
Karl
hi all ive had a problem with my 205 gti6 the gearbox blew up on me lol so i whipped it off to find gear sprockets inside the bell housing it was anhilated :blush: anyway the clutch was fine but the pressure plate was chewed up and so is teeth that send the signal to the crankshaft sensor :angry: so i know i need a new fly wheel and clutch kit any sugestions on either would like to upgrade it really while it is off so i dont have to come back to this many thanks in advance ;)
allye
The Rich W lightened flywheels (from 306gti6 forum) are very good but quite pricey compared to a few quid for a 2nd hand standard item. Clutch wise as long as the engine is standard a good OE valeo or similar is more than enough.
harryskid
Am i right in saying an Mi one would fit as well?
yeah, its the same flywheel.
Karl
thanks does the valeo clutch need tobe mi16 or do i need a gti6 1 thanks
Karl
yeah i have an mi16 one in at the moment jw if there is a better 1 possibly but the clutchis fine its the pressure plate that is chewed
Its usually a push type 1.9 MI16 (BX 16v) clutch that is used
harryskid
Mine has a Mi flywheel with a Helix paddle clutch!
kee
try TTV racing, will make one to suit your needs and quoted me a lot less than that for a ford xflow flywheel and that was for race spec too.
never used them but heard very good things about their work
TTV make the flywheels for Lynx Power engineering, as sold by Rich Walker, so I doubt you will get them much cheaper.
Karl
got that cluth you showed me welsh pug and got a flywheel off rich w many thanks you guys saved me about 90 golden nuggets :D much appreciated
kee
cut out the middle man and buy straight from ttv will save some pennies, from memory I was quoted around £200, that was about a year ago
I dont think they will sell you one direct.
kee
they certainly used to, like I said I had a quote for a race-spec fly for use on my mk1 fiesta and they never mentioned going through a 3rd party.
theres more in it for them selling direct.
They don't do the mi16/gti6 one direct, you have to go through lynx for that one in particular.
moist others you can order direct however.
GTi 6 / Mi16 'Supalite'
With Inductive pulse pick-up
Lightweight billet steel
Single piece design integral teeth
Suits standard diameter clutch
Dynamically balanced
Weight: 4.1Kg
Part number: 0686
Exclusive UK Stockist:
www.lynxpowerengineering.com
Edited by welshpug
kee
very pretty, their work looks very good
