omri617
Help Identifying These Units Please - I'm Confused.
omri617
Hi
restoring my 1.9 GTI and got stuck with these units - i need to know please where are they meant to? thanks a lot. if more pics will help , i will add.
omri617
also i have an issue , the rear fog light gets no voltage - which relay/fuse it responsible for it? the reverse back light works as the plate number light also work .
make sure you have dipped beam on...
omri617
make sure what??
Slo
he means turn your headlights on, the foglight wont work without low (dipped) beam on
omri617
they are on . i checked
anyone recognizes anything from the photos above?
cheers
Slo
bottom left heater control panel, red is a spare not needed, brown one heater rheostat i think, top right looks like a fusebox plug unsure on rest are you mixing phase 1 and 2 wiring by any chance?
Edited by Slo
omri617
Thanks firstly
No mixing , only ph2
omri617
What about this black relay with thick wires attached to it ?
Slo
more than likely and "ingition on" relay to power things that should only be on with the engine running like the heater rear demister etc
The relay is not a Peugeot part, Someone has fitted this
Slo
in that case no one on here will know what its for probably an immosiliser or fog reley the possibilities are endless
