boldy205
V6 Lump
boldy205
Hi, im looking at buying a 406 v6 coupe engine for my 306. Engine is from an R reg (1997) and have heard early ones are the ones to go for, less complicated etc, is this going to be the early engine?
Also, hows the way to go about the removal of the ECU to keep it unlocked?
Many thanks
Matt
Jer309GTi
You've talked yourself into it then! :)
stef205
i think you have the ignition on the 2nd click or running then disconnect the ecu, dont hold me to it tho
boldy205
Not totaly convinced, but have been offered something that might be good!
stef205: Thanks for the reply, anyone else have any conformation?
Matt
ade 4wd
A 97 engine is the earlier one, they changed to the newer multiplexed engine in late 2000. The ECU cannot be unlocked by disconnecting it while the ignition is on. A chip inside the ECU needs reprogramming, i can do this for you.
Batfink
If you are going to use aftermarket management its probably worth going for the newer engine as it made more power...
Tesstuff
Not true Ade, there are three options. D8 , D9 and shall we call it D8 and a half. This is the one to go for. Newer engine without multiplex.
Best to go for the D8 and a half :)
Edited by Tesstuff
ade 4wd
Tesstuff, Are you saying that a D8 and a half uses the newer ES9J4S engine with MP7.0 managment?
Tesstuff
I am saying that the myth that there are two choices, D8 non multiplex and D9 multiplex is wrong.
There was a crossover. Those in the know call it the D8 and a half.
What I know for certain is that it is the ES9J4S engine and it is non multiplex. Don't know the ecu used without asking.
I have heard this, but never seen it :lol:
Also dubious as to whether any cars like this exist as Servicebox only show the J4 engine+ecu for the D8, whereas the D9 does list J4 and J4S.
so it may be that its the other way round....
Edited by welshpug
Tesstuff
No.
Seen it and almost bought it. Plus many more there available to buy.
boldy205
Hmmm, insurance company want another £400 on top of my premium on my 306 one for the 406 coupe. Rip off sods. Im nearly 30, and they want the equivalant of £700 a year, for a wanked out 406. Great!
ideal reasoning to pop the engine in a 306 then :D
boldy205
Thinking the insurance is going to be high though. Plus after spending 25 mins on hold to the insurance company,im hacked RIGHT OFF at the moment!!
StuF215
Many thanks
Matt
I'm sure you keep the ECU unlocked (at least the early ones) by disconeecting the ecu whilst the engine is running. I've never had to send away any of the ecus iv'e obtained to be unlocked when this method of removal was used.
I thought that the crossover via the D8.5 was the esj94 engine but with multiplex loom lol but I could be wrong of course
Stu
