RICH530I
Gti6 Rev Counter
RICH530I
Hello All
I have had one of the following adaptors made up for my rev counter to work again after fitting the GTI6 engine. Could anyone advise me which wires to chip into? There is a purple and a brown one on the coil packs and I have found the infomation below from this site about the plug on the back of the clocks. Any help would be much appreciated
http://forum.205gtidrivers.com/index.php?app=core&module=attach&section=attach&attach_id=1160
the standard gti dashboard\clocks have a plug in connector with 4 pins.
The first should be white, number C1J. This wire is 12v.
The second should be green with yellow stripes, number M1J. This is the earth wire.
The third should be yellow, number 112. This wire is the input from coil.
The fourth wire is only used for diesel models. If you have a diesel, connect it to wire 112A.
Spiky
thats the config for a turbo setup, you need 4 wire to attach to each coil on a gti6 setup
so you have a feed form each coil
1 earth
1 wire to wire 112
if you need a gti6 setup, let me know :)
RICH530I
1 earth
1 wire to wire 112
Cheers for the reply,I forgot to say I have got the 4 wire set up,could you advise me which wire to chip into on the coil packs?
Richard
Spiky
As you look at the plugs from above it's the rear wire :)
RICH530I
Thanks mate its working fine now :)
Spiky
Excellent :)
tonester84
would this be the same for the xu10j4r? most of the wiring i used the gti6 as a guide, so would the tacho be the same as a gti6, ie the dioded loom? thanks
Spiky
Does that have a coil on plug setup, if not you should be able to pick up from the ignition amp :)
tonester84
Sorry not sure that I understand what u mean. If u mean is it on a coil pack over spark plugs, it is. It's not individuals like the gti6, but a one piece item. It has four wires outve the plug. To which from memory, are 12v ign, ground, and 2 signal feeds? Any help would be appreciated thank you.
P.s sorry for the late response but I'd never seen a response until now ha, dam iPad lol
Richie-Van-GTi
For the coil you have, which is a wasted spark coil you would be best running the diode adapter method. Spikey makes them I believe and they work a treat. Ive made a few now and all been successful. Best to PM spikey see if he can fix you up.
tonester84
Spiky
5 min job to wire up too :)
