Dariooo
Remote Central Locking From Later Peugeot
Dariooo
Helo
My 205 has got a remote central locking wiring but it hasn't got a reciver and a remote control. I can easyer find it from a later peugeot and citroen.
Somenody know how to connect a wire to later reciver? I can't find in hayness a wining of 205 remote central locking. Somebody know where to find it? It's some like in 405 maybe?
Thank you
Dario
Dariooo
Another qestion
Can somebody let me know where is the diference between 6552 TN and 6552 N6??
6552 TN
If I look by peugeot 405 is the same party by the same number on picture and it's available. If I look by 205 it's diferent part (number) like N6? I don't get it... :(
I would imagine if you obtain the full wiring loom, or at least all the plugs and lengths of wire, and all the components, you could make any system work.
it has been said that the 405 has some parts that can be used in the ;later 205's
Dariooo
I have a full wiring loom in my car, because in a car it is yet a remote central loking without a reciver and remote unit. I'm need only a remote unit and a reciver. I would install it from later peugeot, because it's easyer to buy it. I'm need a plant of wiring loom from later peugeot or citroen (Like saxo, zx, 106...).
Thank you
cybernck
You might be able to find it in the UK (from a 405), like I have :).
Dariooo
I'm searching something like 405....and from Citroen bx would be fine right? and from 309 it's ok?
Daviewonder
My 205 had remote central locking from a 306 fitted when I bought it.
Dariooo
I think that this in not possible, becaue in service box a 306 has the same part number of reciver like 106...so like the later type of reciver....
Can you take some picture of reciver?
Thank you
cybernck
I recently threw away a 306 receiver (from a 1998 GTI-6) and it was the new type.
lemmingzappa
My old 205 had one from a 405, plugged straight into the 205 loom.
Dariooo
Good, but can you help me to buy somwhere some from 405 plese? I had look on ebay, but I han't find nothing :(
cybernck
Search for a "405 breaking" or something along those lines (there have recently been 3-4 on there) and put up a wanted post on here :).
Dariooo
Ok ;) I will...thanks.. :)
Slo
You can find the same key sender and receiver as the one on the left in the picture in a renault 25 too and probably most of the other old renaults too, that is if you can find any in your country.
Edited by Slo
Dariooo
Sorry, but cars like R25, R21, R5 Turbo...are so rare in our country, like 205 too....I have some reciver of R Clio, but it's diferent...
Dariooo
So another question...I have now a remote unit and a reciver but it doesen't work. Manual central locking work fine but a remote don't work.
How can I test where is the problem? On a reciver comes four wire. Two wire are a power supply (this it's ok)....and another two wire goes on remote locking controller. If I connect on of this with earth a locking work (open), if I connect earth on another one wire, locking work in another direction (close). Somebody know where can be a problem? Battery are ok, also a red light on key work.
Thank you
Dario
