sy84
Engine On Full Throttle
sy84
hi iv got a gti6 converted 205,yesterday i went to start the car and the engine revs rite up as if the throttle stuck open,the cable is free could it be a throttle postion sensor?
rallysteve
Sounds like it could be an air leak after the throttle body, check all the pipe connections and holes on the inlet manifold
Steve
Strictly_Derv
Is it the first start since the engine swap? Could be the TPS wired in wrong.
unlikely, you don't touch the tps wiring.
most likely cause is an air leak or the idle valve stuck open.
Another possibility you're missing one of the switched positive feeds - had this on Pete's (2052006) car that took a bit of head scratching, as it started and ran, just revved its nuts off because the ICV was wide open. Turned out that there was no power to the ICV because one of the switched lives on the loom was missing, hence it not responding and being stuck open.
Easy to check as you should have switched 12v to one of the pins on the ICV (can't remember which off the top of my head - a search should reveal all).
As others have said, an airleak will also cause a high idle speed in the case of GTi-6's - in addition to the usual areas, remember the plastic resonator box underneath the inlet, which is has been known to crack, and the carbon canister connection on the front of the TB that needs to be blocked off.
allye
Mine did this when it was warm after switching off and starting again, cleaned out the ICV and all was well, even starts better.
sy84
no the convertion was done quite a while ago,i parked the car up for half hour when i went to re start it,it back fired then just revs rite up
If it back-fired, I'd be looking at the resonator box for cracks/damage as they tend to break when the engine back-fires...
