MrMemzi 12 Posted March 6, 2012 Whilst on the subject of over fueling. My car currently is a 1600 its been running the 1900 injectors for about 2 years im able to keep up with a friends 106 gti so im not down on power. I tried to change back to the 1600 injectors but the car wont allow it and missfires. Any idea why this is? Share this post Link to post Share on other sites
welshpug 1,737 Posted March 6, 2012 AFM needs setting up properly, or swapping for a 1.6 item. Share this post Link to post Share on other sites
Anthony 1,003 Posted March 6, 2012 Could be all manner of things - running a 1.9 ECU, has the wrong/faulty fuel pressure reg or as Welshpug says the AFM has been messed around with previously. Share this post Link to post Share on other sites
MrMemzi 12 Posted March 6, 2012 Its already a 1.6 afm. And the ecu is "superchipped" as mentioned in another thread. Im still getting good mpg but just a stinky exhaust Share this post Link to post Share on other sites
kyepan 291 Posted March 6, 2012 was it already on 1.9 injectors when you bought it? or did you fit them. same as above, if the afm has been messed to allow the 1.9 injectors to work, prior to you owning it, it will need messing with again for you to return to standard injectors. superchips iirc, remove the rev limit and nothing more. you need to figure out what you're dealing with before going in the right direction. Share this post Link to post Share on other sites
MrMemzi 12 Posted March 6, 2012 I done it myself as i used to tinker with older cars and it used to work very well with them. Just the ecu and injectors had been changed. Also have a ramair filter. Probs just more noise then huge power gains Share this post Link to post Share on other sites
dcc 855 Posted March 6, 2012 could be a dicky fuel pump, dicky FPR, dicky injectors, dirty fuel / filter, wrong or dicky afm. Share this post Link to post Share on other sites
MrMemzi 12 Posted March 6, 2012 Actually my fuel pump started making a funny noise when i fired her up after 1-2 months of neglect like a whining. Possible dying fuel pump? Share this post Link to post Share on other sites
