starky5
A Few Electrical Issues!
starky5
My battery light has just started flickering every now and then, its not on all the time so I'm reluctant to think its the alternator and more of a connection issue. But I can only see one wire going to my alternator and I would have expected to see 2, am i missing something here?
Also on start up what dash lights should come on? With the ignition on but the car not started the battery light, coolant level light and the next one down again dont light up. I believe this is one of the things the new MOT picks up on so would like to start fault finding once i know what should and shouldnt light up.
johnnyboy666
first thing to check would probably be to make sure any earthing points are well connected and not corroded
starky5
Any idea what connections i should have though as i can only see the 1, it looks in ok condition not tip top but certainly a good connection
shonkers
there should be a pull off spade connector and a 10mm nut connector on the alternator ive just took mine off
Josh_Quant
I agree, ;)
starky5
I have a spade connector hanging next to my alternator! ill have to find where it plugs on in the day light as i couldnt see in the fading light this eve
